HELP!!!!Smoke from turbo
Old Jul 10, 2007 | 11:26 AM
wrxisthebest's Avatar
i am getting smoke from my engine bay when i am either cruisin or at idle!!
i pop the hood and it is coming from my turbo!
i have been told it could be an oil fitting on the turbo but im not sure!
it only happens when im not boostin' so bascically only when oil is going to my turbo
any help would be appreciated
and i know the turbo isnt cracked cause i am still gettin plenty of boost(15psi)
Old Jul 10, 2007 | 11:50 AM
strider327's Avatar
Car Info: 2005 WRX
probably the seal.
Old Jul 10, 2007 | 01:43 PM
really???
im thinkin of just buyin a new turbo!
vf sumethin' just better than the freakin lame td04
Old Jul 10, 2007 | 06:11 PM
strider327's Avatar
Car Info: 2005 WRX
If your gonna buy a new turbo and your sticking with stock go for the 06 or 07 wrx TD04. Much much better and reliable compared to the earlier years. And if your doing an upgrade thinking of the VF34 or VF39 go for the 07 sti turbo the VF43 no leaks and built to last. Good Luck.
Old Jul 10, 2007 | 06:38 PM
WhiTe_07_WRx's Avatar
Car Info: suby
^^^^AGREE couldnt be more perfect. But if u do upgrade remember To upgrade ur Fuel pump, and Injectors as well, Since the earlier year WRXs need bigger injectors to run a VF34 or VF39
Old Jul 12, 2007 | 09:34 AM
greddy 18g
Old Jul 12, 2007 | 02:14 PM
uNTuCHaBLeZ_WRx's Avatar
Car Info: no
I told you tho, I know ur leak is comin from the oil return line, and I be its the Oil reutrn line gasket
Old Jul 13, 2007 | 10:00 AM
AzN121184's Avatar
Car Info: civic
prolly the oil line. i had this happen to me before as well due to a crack on the weld of the line.
obdrummer
May 21, 2014 06:33 PM
CcaniaSTI
Dec 20, 2012 09:46 PM
DerekB707
Feb 16, 2010 08:25 AM
Chrisnonstop
Jul 17, 2008 08:48 AM
DougZ
Mar 29, 2006 02:15 AM
