Running too rich
Old Apr 7, 2003 | 09:23 PM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
RallyKeith, an A/F gauge/setup is not the first thing that is to be installed on a car. First of all it's cost prohibitive to have a wideband setup placed in car. And no a Greddy or Autometer narrowband A/F gauge does not count at adequate.
What you need first and for most are Boost and EGT gauges. From there you can see what boost levels your running and from EGT's you can see if your running rich or lean. Obvioulsy you can have more engine monitoring equipment like oil pressure, oil temp, fuel pressure, coolant temp, etc... But at least Boost and EGT are a must, everything else is icing on the cake...
As for running rich... The Subaru Impreza does run rich from the factory. It's a design built into the WRX so be safe and conservative. On a stock WRX, you can go to richer then 10:1 at WOT. Forced induction cars need to run rich for a reason. Last thing you want to do is knock to death.
For first mods, look into opening up your exhaust system with a catless uppipe and some sort of turboback or even TurboXS's Stealthback which retains the stock muffler for a 'stealth' look. Then when you get a boost controller, a boost gauge MUST be installed to correctly monitor boost levels. With these mods alone you should be in the mid 13 sec range on the 1/4 mile.
Then you can look into getting better tire, better brakes, a better suspension... The list goes on and on.
Old Apr 14, 2003 | 05:57 PM
Br1t1shguy's Avatar
Car Info: 02' WRX
Re: Re: Running too rich
Originally posted by RallyKeith
The Absolute FIRST thing you should do to a car you plan on modding is install an Air/Fuel Meter. This is absolutely necissary to determine what is going on in your engine and how it is running. Modding and doing things like running more boost with out seeing what the air/fuel ratio is can be catastrophic to the motor. A motor that goes lean under boost can self destruct in a matter of moments.
Ok, Drama mode off now. What I said above is really true. A little too rich is better than any bit Lean. I personally feel an A/F meter is vital on a turbo car, especially one pushing the limits of stock components. Who konws, maybe your car really is running fine, and you just have a heavy foot
Good luck
The absolute first thing you should do is throw you're A/F gauge out the window. Unless it's a wideband with a proper A/F computer (the gauges are far too slow at calculating to give accurate mesurements) it's trash. Narrowband show gauges are worthless for tuning.
SubieStylez
20
Mar 29, 2006 05:26 PM
xitonedefix
Feb 15, 2005 11:13 PM
WRXYBOY
May 18, 2004 08:13 PM
BluWrX.03
May 7, 2003 11:33 AM
wonton2049
May 4, 2003 06:29 AM
