hesitation starting out
Old Apr 2, 2003 | 09:08 PM
sgwrx's Avatar
Car Info: 03 Sedona Red WRX
hey. i had an 02 and now an 03 wrx. on both i noticed that, if i start out and shift up into 2nd gear such that the revs drop down to about 1500rpm, then hold the pedal in to accelerate, i get some hesitation. like a slight pulling up to say 3,000rpm.
anyone else notice this?
i just turned 1000miles on it and had the oil change. with the 02, i noticed it the entire time i had it. the 02 also had clutch shudder problem.
Old Apr 3, 2003 | 03:27 AM
Wingless Wonder's Avatar
Normal. It's a small displacement turbo motor with low compression. This means that before the onset of turbo boost, there is lag. The turbocharger has a range of efficiency and you are asking it to perform outside of that range. Solution - shift at a higher rpm - rev higher!
Old Apr 7, 2003 | 02:49 PM
sgwrx's Avatar
it's one of those things...
that i hear about, read about and never experienced. the first time i thought it was like the clutch slipping or, the computer needing to be reset (mixture issues or gas issues or something)... then when i experienced on the new 03, i figured i should ask and that it was pretty normal.
so here it is : "well i'll be darned! that's what that is. hm, that's something". hahaha
thanks
Old Apr 14, 2003 | 03:33 PM
rentankonko's Avatar
Car Info: 2.5rs with Eighteens!!!lol
Yeah, I drove a WRX (my friend's) for an extended period of time, and for the first time, a couple of days ago. I own a 98 RS, and one cannot drive the WRX like an RS, or else that lag and low compression will make you come within an inch of stalling and at times make the drivetrain buckle menacingly...but I still want to put a WRX engine in my Impreza. The lag just means you have to adjust your driving technique.
Old Apr 14, 2003 | 05:58 PM
Br1t1shguy's Avatar
Car Info: 02' WRX
all you gotta do is shift higher so it drops you at at least 3500rpm and you'll have gobs of power on hand.
Old Apr 15, 2003 | 12:45 AM
Bishop's Avatar
Car Info: 2003 WRX 5-Spd,short throw, premium sound, security, yellow... stock... MINE!!
I bought a 00 RS in Oct. of 00, drove it till last month when I got my rex. I completely know what your talkin about, as everyone else has said, its normal... shift later.
I still love to drive the RS though, NA feeks much more... excited... than the turbo, but still would never go back. You'll get used to it
STiNightFall
Sep 4, 2004 02:13 AM
NeVzWRX
Jun 23, 2003 11:38 AM
jimr
Feb 18, 2003 08:54 PM
Mandra
Jan 2, 2003 05:55 PM
wrxtacy
Dec 12, 2002 12:40 AM
