running catless dp, getting CEL (was: Bad for the car?)
Old Apr 28, 2005 | 09:23 PM
knightsnke's Avatar
Car Info: 2003 WRX
Bad for the car?
Few questions.. On a WRX does the uni-chip or whatever you call it, change the air/fuel ratio, from the readings on the 2 oxygen sensors to keep it at the right level? and if so, will using a catless downpipe effect the air/fuel ratio reading for the engine? thanks... I do get a check engine light all the time due to the catless downpipe, am i hurting my engine? thanks all
Old Apr 28, 2005 | 10:05 PM
itwrx's Avatar
Car Info: 03 WRX Blue
You need the cel fix. I believe its a small resistor. Check out the vendor forums I believe they could help you a bit more
Old Apr 28, 2005 | 10:11 PM
ShiroStee's Avatar
Car Info: 05 sti
use search, i saw a similar thread to this either earlier today or yesterday. You can just buy a cel fix for less than $15 from one of the vendors. Plenty of people run catless dp's. It's fine as long as the tree huggers don't find out
Old Apr 28, 2005 | 10:36 PM
subabu05's Avatar
Car Info: 05 WRX Wagon
catless
Hey,
I'm running a catless tbe from the uppipe. You do need a resistor to prevent the CEL. It's a 2.2k ohm 1/2 watt. I bought a pack of 5 (you only need one but that's the fewest you can buy) from Radio Shack for 99m cents. No more CELs.
http://www.scoobymods.com/forums/sho...hlight=cel+fix
Good luck and enjoy your cat free exhaust!
Ben
Old Apr 29, 2005 | 04:54 AM
knightsnke's Avatar
Car Info: 2003 WRX
ok but is my engine getting harmed in the process, since the o2 sensor is reading high levels of carbon monoxide is it changing the air/fuel ratio to the engine when it shouldn't be?
Old Apr 29, 2005 | 11:02 AM
knightsnke's Avatar
Car Info: 2003 WRX
I Don't Care About The Cel Going Off What I Want To Know Is Since The Car Thinks Im Running More Gases Since I Don't Have Cats, Is It Telling The Ecu To Change The Air/fuel Ratio Going Into The Engine???
Old Apr 29, 2005 | 11:13 AM
mbquarts's Avatar
Car Info: 03 MBP WRX
I'm pretty sure that the ecu sets the a/f ratio based on readings from the MAF sensor in the intake. That is why people have issues when they use cold air intakes.
Old Apr 30, 2005 | 12:29 AM
knightsnke's Avatar
Car Info: 2003 WRX
i use a cold air intake and havent had any noticable problems,,
Hondaru
Nov 20, 2010 05:21 AM
RaginBull
Dec 1, 2006 08:24 PM
xicema17x
Jan 14, 2005 01:41 PM
SacWagon
May 9, 2003 11:04 AM
wonton2049
May 4, 2003 06:29 AM
