RPM's For Best Launch??????
Old Aug 28, 2004 | 10:43 AM
wssboard18's Avatar
4k-5k rpm's would be about right, but i would recomend not dropping the clutch, but rather slipping the clutch. Also use the search button in the upper right hand corner of the screen b/c I think this topic has been covered extensivly.
Old Aug 28, 2004 | 05:14 PM
kettsupp's Avatar
5000rpm
Old Aug 28, 2004 | 10:54 PM
awns729's Avatar
Car Info: want a WRX
Depends on how long you want your car to last. Usually people launch between 4000-5000 RPM and SLIP the clutch. Depending on how often you do this, you may need to replace the clutch in as little as a year (or maybe 2-4 years, it really depends) and if you pop the clutch you might break your tranny.
Old Aug 30, 2004 | 01:56 PM
GasPipe DreameR's Avatar
Car Info: lowered blk04 with no motor
i do it about 5k-5.5k
Old Aug 31, 2004 | 01:24 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
I like to bring it up to ~4000RPM, then floor it and slip the clutch very quickly as soon as it hits 5000RPM. This builds a bit of boost on the launch and helps you break the tires loose just a bit.
-- Ed
Old Sep 5, 2004 | 05:12 PM
AWD 20T's Avatar
Car Info: 2009 G Ride
Originally Posted by litebrite2001
I drop my exedy drag clutch at about 5000-5500. Transmission is still holding, but you need big cahones to do this with a 75 shot on a TXS stage 4.
Wow man I really hope you aren't doing that! If you are, you better pray that your tranny lasts another month, because that is just insane!
Old Sep 5, 2004 | 07:45 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
big cahones? more like a lot of money in the bank...
-- Ed
Old Sep 13, 2004 | 02:43 PM
KAX's Avatar
KAX
And some nice gears
Old Sep 13, 2004 | 05:58 PM
My_Red_Suby's Avatar
Car Info: 2005 Metallic Gray STI
R U talking about drag racing?
Old Sep 18, 2004 | 09:58 AM
awns729's Avatar
Of course
michaelstang
Aug 20, 2006 01:31 AM
djtmalta
May 2, 2005 12:30 PM
808_REX
Mar 16, 2005 03:49 PM
Drebone8
Apr 28, 2004 09:56 PM
