Read many cheap mods, but what actually works?
Old Jan 9, 2004 | 06:07 PM
Daredevil's Avatar
go with helix
ist larger in diameter, and well worth it
grounding mod is good and cheap, i went with it, though nothing hugely noticable
pullin it through the top takes longer, and im not sure how easier it is compared to doin a lift, but i think it just takes long
i did it this way, i did not lift my engine
hope this helps
while you're at it, get a turbo back
Old Jan 10, 2004 | 01:36 AM
Choku Dori's Avatar
Car Info: Corvette Z51
Be careful with the 3/16 mod -- it's been a pain for some people that have done it. It's very subjective considering the wide variations in results.
Definitely go for the Helix upipe.
A mod that works very well is disabling the dorky daytime running lights, especially if you have aftermarket bulbs.
Old Jan 10, 2004 | 02:23 AM
Daredevil's Avatar
i like the day time running lights for 1 reason
if it is at night... and im doin somethign maybe a little illegal and a cop comes by..
turn off my headlights, i can still see the road, but by turning off the headlights, it turns the light off the license plate, for easier getaways
Old Jan 11, 2004 | 10:31 PM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
From the bottom, without the lift. Just grind off that heatshield bracket that's on the uppipe. You only have to cut off less than half of it, and it will slip out.
Gutting an uppipe will NOT take 4 hours with the proper tools. A big screw driver and hammer to get the big chunks out, then a drill and stiff wire brush to remove the tiny bits.
Old Feb 9, 2004 | 05:58 PM
MO REX's Avatar
Car Info: 02 PSM WRX
Replace the restrictive hose coupling betweem the wastegate T and the boost silinoid with a 3/16 coupling. The butt dyno didnt feel that much of a difference but the boost gauge showed that boost would build alittle earlier and last a little longer. Also get about 3 more lbs of boost in 2nd. You can find this mod at scooby mods. It costs around $1 so its worth a try. Im no expert but I wouldnt think it could cause any harm.
Old Feb 10, 2004 | 07:09 AM
VRWRX's Avatar
Car Info: 2005 CGM WRX Wagon
Isn't it Sun Auto that has the good grounding kit?
SR-DIABLO
Apr 23, 2009 03:31 PM
blacktraxgirl
Jan 16, 2007 08:32 PM
gdogg
Aug 17, 2006 02:48 PM
corndogs
Cars For Sale
Aug 9, 2004 08:39 AM
Salty
Aug 15, 2003 01:20 PM
