Question about da boost
Old Oct 21, 2003 | 09:29 PM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
I would not go more then 16
Old Oct 22, 2003 | 11:39 AM
mmboost's Avatar
Not worth it... not healthy. Search for compressor maps on our turbos on I-Club (if you know how to read them).
Once you go past a turbos efficiency range you get higher boost readings because as it self-describes, you have more pressure. But pressure comes from one of 2 things: more air mass or more air volume. As the turbo has to work harder it soaks heat into the compressing air from friction and turbine /exhaust gas. You get to the point where the heat from the system makes air so expanded that the pressure gets higher even though the mass of air you take in remains the same or even gets smaller. This basically means you are putting more stress on the whole system for nothing but the right to say "I boost 17psi". Not will be slower than everyone else but your turbo dies twice as quickly
jason
Old Oct 23, 2003 | 01:28 AM
Daredevil's Avatar
nice answer, thanks
Old Oct 23, 2003 | 07:57 PM
Bingo.
yzercyber
Aug 12, 2005 03:42 PM
Astacun1
Jun 28, 2003 03:12 PM
mattr762
Apr 18, 2003 09:12 AM
ShokWaveRider
Feb 21, 2003 06:14 AM
XwrxX
Dec 17, 2002 07:14 AM
