overheating with new radiator
Old May 19, 2003 | 06:43 PM
Hybrid22L's Avatar
I just installed a PWR radiator and zerosport thermostat and I seem to be overheating, My needle is hitting 3/4 of the way up on idle. I'm using 70% distilled water and 30% prestone antifreeze with some redline water wetter. Is there air trapped in the cooling system that is casusing me to overheat; if so, how do I get it out to fix the problem. Any help would be great.
Old May 19, 2003 | 07:12 PM
DeliciouSpeed's Avatar
Why do you think there may be air in the system? Didn't you bleed it, if not that can be the cause.
k2
Old May 19, 2003 | 08:22 PM
Hybrid22L's Avatar
yup,
I didn't bleed it. I just got done doing it for a while. But the needle still seems that it reads around the stock area. I will try it some more to see if it still has air in it.
Old May 19, 2003 | 11:41 PM
BlueGargantua's Avatar
Turn the heater on and let the possible trapped air escape from there as well. I have a MRT radiator and there is no change in where the "needle" on the stock temp gauge reads even after the burping of the system.
Old May 20, 2003 | 06:58 AM
Yeah bro, the needle should stay in the same general location.
The engine needs to be within a certain temp range to run properly.
Old May 20, 2003 | 08:02 AM
Hybrid22L's Avatar
I just finished up last night and no overheating. So I guess all of the air is out. Thanks for the info guys.
Island Style
Hawaii Classifieds
May 12, 2010 05:41 PM
Subadubaru
Feb 10, 2010 10:35 PM
hypnotics06
Apr 3, 2009 11:25 AM
sneakywrx
Aug 14, 2007 01:43 AM
