Is it better to have a higher or lower pressure radiator cap? (was: Radiator cap Q?)
Old Aug 13, 2007 | 09:09 AM
sneakywrx's Avatar
Car Info: 2004 subaru wrx
I was checking out a few days ago a Greddy radiator cap when I noticed that the piece is a 1.3 (127kpa), but my stock cap has a 137(kpa), my question is do I have the better cap or is the lower the kpa, the better, sorry for the ignorance it's just that i've never paid too much attention to how exactly the radiator caps function, thanks in advance guys!
Old Aug 13, 2007 | 10:05 PM
L and E Fab.com's Avatar
Former Sponsor
Car Info: '95 Impreza WRX Rally
higher the kpa the better.
Well kinda too high and it can cause problems.
But the fact that the stock cap is higher I would stick with the stock cap.
Even the "STI" radiator cap is rated at 1.3 bars.
Old Aug 14, 2007 | 01:43 AM
Wingless Wonder's Avatar
Ideally, a replacement cap should match the pressure rating of the factory radiator cap. Maintaining a pressurized cooling system will raise the boiling point of the coolant as long as the system has no leaks. The cap will vent coolant to the overflow reservoir bottle when the system begins to exceed the rated pressure of the cap.
Raising the boiling point temperature of the coolant eliminates air bubbles in the cooling system. Once air pockets start to form, overheating is imminent because the cooling system will not be able to draw heat away from the engine where air has formed. If the hot spots form around critical areas (which they usually do) like the combustion chambers or near the exhaust ports in the cylinder heads, the heads can crack from overheating.
For street-driven cars, I wouldn't mess around with caps other than genuine Subaru parts. Going too high or too low with the pressure rating on the radiator caps may cause problems.
huck
Aug 23, 2017 02:18 PM
Island Style
Hawaii Classifieds
May 12, 2010 05:41 PM
MY04PSM
Feb 11, 2004 07:14 PM
0260B4U
Feb 6, 2004 06:12 PM
holmskillt
Nov 19, 2003 06:39 AM
