Low Boost??
Old Aug 9, 2007 | 02:49 PM
SicStar's Avatar
Car Info: 05 WRX/STI Hybrid
Angry Low Boost??
I have a 05 wrx with a Vf39, ecu reflash (vishnu), Sti pinks and fuel pump, and I,H,E. The seals went bad in the Vf39 and I sent it to deadbolt to get rebuilt. Before I was boostin to 18psi. And now that I got the turbo back and put on, I am only boostin to about 14 psi. Can anyone help me. Thanks in advance.
Old Aug 10, 2007 | 09:50 AM
Oogie's Avatar
Car Info: 99 M3
Did you install it back yourself? Possible boost leak in the piping?
Old Aug 10, 2007 | 01:24 PM
03_Impreza_Al's Avatar
maybe you need to tighten your WG arm? =\
Old Aug 10, 2007 | 02:49 PM
DarkScooby's Avatar
Car Info: 2004 Wrx
If I were you, find someone that has a boost leak tester and run it on you car, it will tell you where your leaking from.
Old Aug 10, 2007 | 04:28 PM
AutoHQ's Avatar
Former Sponsor
Car Info: Shops cars: 07 STI & 07 Lotus Exige S
You're welcome to bring your car to our shop and let's talk about it.
Old Aug 10, 2007 | 05:16 PM
SicStar's Avatar
Yes, I installed it myself. The Vf39 doesn't have an adjustable WG arm. I will perform a boost leak test and see what happens.
Old Aug 11, 2007 | 10:01 AM
SicStar's Avatar
I tried to do a boost leak test and couldn't get it to hold psi at all. Does anyone know how to perform a boost leak test on Subarus??
Old Aug 11, 2007 | 07:36 PM
SicStar's Avatar
Got the test to work and everything is fine, but still only 11-13 pounds. Any help please.
Old Aug 13, 2007 | 10:07 PM
L and E Fab.com's Avatar
Former Sponsor
Car Info: '95 Impreza WRX Rally
Make sure your Boost Controller is working properly. Mine went out the other day and it dropped down to 12 psi. installed one of my spares and back to 20psi.
Old Aug 14, 2007 | 06:01 PM
SicStar's Avatar
Talking
Problem solved. I had the vacume lines switched that go to the waste gate actuator and the turbo. Oooops!!
djwonder925
Apr 21, 2013 12:05 AM
Shaitiger
Apr 8, 2003 10:00 PM
Shaitiger
Wanted
Apr 6, 2003 09:31 PM
Shaitiger
Apr 2, 2003 12:09 AM
Shaitiger
Mar 30, 2003 11:22 PM
