Oil in the intercooler???
Old Mar 30, 2004 | 02:07 PM
DJ Catchem's Avatar
Car Info: '02 WRX sedan
Unhappy Oil in the intercooler???
...so I'm still on a mission to get my funny boost spiking issue (which has been chronicled in several threads in here in the last 4 months) fixed, and with the car in the shop, there's a definite pressure leak under boost, like the wastegate isn't holding pressure properly. Swapping the I/C and BOV in from another car yields the same thing, so it's not either of those two, but the tech noticed a bit of oil in my intercooler when he removed it.
Has anyone else come across this, or know what it could mean?
THanks in advance...
Old Mar 30, 2004 | 02:27 PM
ish's Avatar
ish
it happens on most wrx's
Old Mar 30, 2004 | 04:31 PM
DJ Catchem's Avatar
WHat about the boost issue, though? It really sounds like the wastegate is sticking open, and the turbo is pulsing power at heavy throttle. Could this all be indicative of a dying turbo or wastegate?
Old Mar 31, 2004 | 07:19 AM
DJ Catchem's Avatar
That's good to know on the oil.
As far as the boost issue goes, we've been through everything. Vacuum lines are where they need to be, and none are broken. the intake tract has been pressure tested to no faults. The boost solenoid was checked. The BOV and I/C were checked. Other than a removed intake silencer, and a Helix up-pipe, the car is stock, and the problem existed before those mods.
It's a head-scratcher...
Old Apr 1, 2004 | 06:51 AM
Vicore_Wrx's Avatar
Car Info: 2003 WRX, blue
oil catch can better safe then sorry
Old Apr 1, 2004 | 12:39 PM
Peaty's Avatar
This has been working for me:
http://www.scoobymods.com/forums/sho...&threadid=2769
However, I like this idea better:
http://www.scoobymods.com/forums/sho...&threadid=3346
Old Apr 3, 2004 | 09:31 PM
BobbyD's Avatar
how did you check the boost solenoid?
thanks
--bobby
Old Apr 3, 2004 | 09:48 PM
jpsimon's Avatar
hey dj, i think i have the same problem + sometimes the car wont run full boost... it vary's everytime i turn the car on.. sometimes ill run full boost and everything will be normal.. other times ill run horrible low crappy boost and the car will just rev and not really produce any power... and sometimes i will get boost spiking like you say..
do you get any of the same symptoms?
Old Apr 4, 2004 | 06:33 AM
DJ Catchem's Avatar
Bobby - I tried unplugging the solenoid to see if the car went into limp mode, and even there, I got the same surging. It's at the garage right now, and on Monday they're swapping a solenoid from another WRX to test it fully.
JP - Mine does similar things to what you're describing, but it's not so varying. I never get a good day where things are normal, but I never get low boost, either. Basically, if I run the car at half throttle, boost will build normally right up to redline. As soon as I go WOT, though, it starts to surge on and off instantly when it gets over about 3500 RPMs. It's crazy.
Hmmm...I wonder. Is there anyone that could tell me if it could be an issue with the Throttle Position Sensor? Could that do it?
huck
Aug 23, 2017 02:18 PM
STi_Mark
May 12, 2007 09:25 AM
Antonio85
Jun 24, 2005 10:24 AM
Slack
Aug 25, 2003 09:45 PM
Zoeb2s
Dec 30, 2002 10:43 AM
