oil in the intercooler
Old Jul 20, 2006 | 01:32 PM
stikllr's Avatar
Car Info: 04 wrx
Question oil in the intercooler
i have a 04 wrx with sti short block, vf34 turbo, sti pink injectors, walbro fuel pump, hks DP, helix UP, 5zigen straight through muffler, ecutek engine manegment. Car keeps misfireing cylinder 2 and 4, and has oil in the intercooler, had head work and a valve replaced but missfire continues. Shop says engine is in good shape. Also have 2002 wrx ecu in car. If anyone has any ideas please help.
Old Jul 20, 2006 | 11:46 PM
testes1010's Avatar
the oil in the IC is normal if you do not run a catch can, get one if you don't.
1) swap the coilpacks from 2 & 4 to 1 & 3, reset the ecu. If the misfires move to 1 & 3 your coilpacks are bad, otherwise goto step 2.
2) check your plugs, proper gap should be around 0.030", make sure they are the correct plugs. NGK BKR7*.
Old Jul 21, 2006 | 06:38 AM
ipozestu's Avatar
Car Info: Broken Subarus
Do a compression test on it. I just had the same problem turned out the ring lands on #4 got wiped.
Old Jul 23, 2006 | 02:35 PM
stikllr's Avatar
Car Info: 04 wrx
swaped coil packs misfire cylinder 4 continues
Old Jul 23, 2006 | 02:37 PM
testes1010's Avatar
more than likely its your plugs...
huck
Aug 23, 2017 02:18 PM
STi_Mark
May 12, 2007 09:25 AM
Antonio85
Jun 24, 2005 10:24 AM
Slack
Aug 25, 2003 09:45 PM
Zoeb2s
Dec 30, 2002 10:43 AM
