33,000 miles and smoking
Old Jul 9, 2006 | 02:20 PM
airforcesubie's Avatar
Car Info: 02wrx wr blue
hi i have a 02 wrx that just turned 33,000 miles, it has a hks downpipe and a pit performance bov. My problem is that every other day day it wll start smoking, not huge clouds at first just small tendrils at first, sometimes at start up sometimes when sitting at a red light. it is a black smoke. ia am not running anything after the down pipe and i have o2 sims. anyone have a clue to the cause or fix? (i have factory shop manuals and it has nothing listed)
Old Jul 9, 2006 | 04:00 PM
Galli916's Avatar
Car Info: MBP Bugeye
My guess would be you're running rich with the BOV.
Old Jul 9, 2006 | 05:02 PM
SubyN00by's Avatar
any oil in the turbo/ic hosing? Turbo might be pukin'. That's a lot of time sitting around for an 02 with 33,000.
Old Jul 9, 2006 | 08:41 PM
hayn_wrx's Avatar
Car Info: 02' wrb wrx w/ RGII
ya could be the bov...i have an 02 wrx also with 28k...i think im running a lil rich cuz the exhaust has a stink smell sorta....could it be cuz ur in the airforce that ur car sits ?...same here..well air guard..later
Old Jul 11, 2006 | 05:23 PM
checked i/c pipes, small amount of oil found in hose from throtle body to i/c. I`m running royal purple and several people told me i would have some leakage doing it. would running just a hks down pipe with no exhaust be hurting it also?
Old Jul 11, 2006 | 07:37 PM
SubyN00by's Avatar
downpipe will have no effect on anything, but to have some oil in the throttle body means that your turbo is starting to puke some oil, meaning that only having 33k miles, it was sitting for a while, the seals could be going out on the turbo dumping some oil in the engine and making it smoke a little. Where are you located?
Old Jul 16, 2006 | 04:36 PM
right now i`m in nc stuck at fort bragg tossing paratroopers
Old Jul 16, 2006 | 04:38 PM
i found a shop that says i need a whole new turbo, they a trying to get me to buy a turbonetics unit that is supposed to be good for 450hp, thats nice but it worries me because the rest of the car is stock
Old Jul 16, 2006 | 05:22 PM
SubyN00by's Avatar
turbo is pukin' oil. I would either replace with a stock turbo, or put something with a little more juice, possibly vf34. Remember that when upgrading the turbo, you will need to purchase new injectors, a new fuel pump, and get your car tuned. You may want to do a leak down/compression test in order to make sure the block is still ok and is going to be able to handle a new bigger turbo.
My personal suggestion would be to replace with a stock turbo for cost reasons, and also to run the car a little and see if it is able to handle the normal boost before puttin it to work with some good boost.
Old Jul 17, 2006 | 09:41 AM
Talking
the reason i was going to go with the turbontics unit is they want to do a partial sponsor, it ends up so it is actually about 300 more than the stocker including all labor. i have a good aftermarket warrenty that is paying for all but the three hundred dollars. they will also get me a new block if i crack it :-). they want me to use a turboxs dual stge boost controler and a cobb acess port so i am trying to find them cheap.
Old Jul 17, 2006 | 09:51 AM
SubyN00by's Avatar
boost controller and access port?
don't forget the injectors and fuel pump, or they'll be buying you blocks for days!
Old Jul 17, 2006 | 10:10 AM
trying to locate those right now, dont want to go to big but i found some that flow over 800cc that seem good and i am using my holley fuel pump out of my mustang
Old Jul 17, 2006 | 10:14 AM
SubyN00by's Avatar
sounds like you got it covered, let us know how it turns out!!!
Old Jul 17, 2006 | 10:35 AM
Talking
probally with tranny bits all over the ground oh well i geuss i will have to get the six
Old Jul 23, 2006 | 03:31 PM
WRX409's Avatar
Car Info: 04 WRX
I was thinking the same thing.Why people put BOV's on
their Subaru's I will never know?
Ballz
Mar 30, 2009 04:40 AM
SubieBabe
Jun 11, 2007 10:16 AM
medicSTi
Mar 16, 2007 01:43 AM
Salty
Feb 9, 2007 10:09 AM
Tommi
Cars For Sale
Apr 20, 2005 05:48 AM
