oil change
Old May 23, 2003 | 07:45 AM
  #36
Acadian's Avatar
Car Info: 2016 WRX Limited
Originally posted by SilverSti
if you change a new WRX's oil at 1,000 miles congrads couse you just blew the engine.
you got to be kidding?
I was told that Subaru's don't use any break in additives in their oil?
Old May 23, 2003 | 09:03 AM
  #37
Peaty's Avatar
They don't use any special break in oil. I've had 10 new cars (3 of the Subaru's ) and I change the oil typically at 500 , 1000 and then every 3K miles after that switching to synth at the 10K mark never a problem.
Old Jun 1, 2003 | 12:24 AM
  #39
psychobooe's Avatar
I have a serious question, if I may. Is it really possible to change the oil filter without changing the oil? I'm just under the impression that the oil would pour out hardcore.
Thanks.
P.S. I'm no engineer. I'm studying Military History.
psycho
Old Jun 1, 2003 | 07:13 AM
  #40
Peaty's Avatar
Yes you can change out just the filter. Some oil will come out but not all. The oil filter is higher than the oil pan. If you do that it would be best to fill the filter with as much oil as possible before installing it, start the motor, shut it off and check the level. You'll need to add back a little I'm sure.
salvator_rizzo
Jul 10, 2009 04:10 PM
nation
Apr 17, 2009 01:16 AM
yzercyber
Mar 2, 2008 06:02 PM
Fa9-Wrx
Apr 29, 2007 08:17 PM
evsoul
18
Oct 26, 2006 12:44 AM
