Obd P0301
Old Aug 6, 2004 | 02:45 PM
xom's Avatar
xom
Car Info: 04 GTO 5.7
Obd P0301
this came up a couple of days ago and I cleared it because car was running fine. Has any one else been getting cylinder 1 missfire codes, or any 302,303,304 codes? I've been running Cobb stage 2 91 octane for awhile now and this just showed up. A friend has a stock 04 wagon that this happened to and the dealer said the car was running fine and that the ecu was messed up and then sent the ecu to NJ to get fixed.
Old Aug 6, 2004 | 03:38 PM
psoper's Avatar
250,000-mile Club President
Car Info: MBP 02 WRX wagon
Do you still have the stock flywheel and pullys? if the Cobb stage 2 involves changing pullys that's probably your culprit.
In my case its the flywheel and nobody has offered any suggestion on how to go about fixing it
Old Aug 6, 2004 | 06:14 PM
mmboost's Avatar
psoper,
"international B" might know.
xom,
do you have a 100% atmo BOV? Sometimes the flashed or base maps for the utec run very rich to be on the very safe side. Coupled with an 100% atmo BOV this can dump a ton of fuel when shifting, occasionally causing a misfire. (Happened to me with a p0304)
jason
BXR_PWR
Apr 25, 2008 05:22 PM
OMB_Godfather
Jan 1, 2007 11:53 AM
rallied out wrx
Sep 7, 2006 07:41 AM
yellow03 rex
Feb 25, 2006 04:54 PM
the5ilenced
Nov 8, 2005 12:44 AM
