Need some advice...
Old Nov 18, 2014 | 10:56 AM
121toberryessa's Avatar
Car Info: SwagonNdaWerks
Need some advice...
Started my car today and heard a loud nosie coming from the engine bay on the front driverside area, lasted for about 30 seconds then went away. A little worried I drove it for maybe ten miles rounds trip. As I was driving I could here a light whislting from the same area while I was in the car. All gauges were fine, temp good, no check engine light, and the car drove great.
Im thinking my water pump may be going out soon, but im not 100% sure. has anyone else had this problem?
The car is a 2003 wrx with 111,xxx miles...runs like a champ. Would do a sreach but at work, just wanted to post real fast.
Old Nov 18, 2014 | 12:33 PM
Brfatal's Avatar
Technical Know-It-All
Car Info: '02 WRX + '15 WRX
Didn't you change the water pump just 6k miles ago as part of the 105k service?
So it just sound like a belt or...?
Old Nov 18, 2014 | 12:45 PM
No I did not, but the belt was done at 60,000
Old Nov 18, 2014 | 12:46 PM
Sounds like more then the belt. Maybe the bearing
Old Nov 18, 2014 | 05:00 PM
Subi3's Avatar
Car Info: 2011 WRX Limited, 2005 STI, 2002 WRX
Could be your Clutch "throw out Bearing" Does it only make the sound when you press the clutch pedal >
Mine has been a little noisy on cold mornings.
Old Nov 18, 2014 | 06:20 PM
No it started maybe 15seconds I started the vehicle and lasted for about 30seconds, pretty sure its the water pump, being that it has never been changed.
Old Nov 18, 2014 | 06:33 PM
1JavaBlk_in_Sac's Avatar
Car Info: $2000 hawkeye
Is it squeaky sound?
Timing belt idler pulley?
Mine failed after 30K miles of installing it.
Old Nov 18, 2014 | 06:50 PM
Holdenian's Avatar
Car Info: 2004 Subaru WRX
Not related, but may I ask how your pulley failed after just 30k? Just did timing belt and wanna make sure I didn't fall into the same footsteps
Old Nov 18, 2014 | 07:26 PM
Not really a squeaky sound at first, just a loud humming nosie. That sucks about your timing belt idler pulley, Im looking at doing the same job...hope i do it correct. Yikes, did it damage any other parts?
Old Nov 18, 2014 | 09:42 PM
I don't know. I guess Gates pulley was faulty.
Hell yeah it did, timing belt skipped 4 teeth, it resulted in slightly bending 4 exhaust valves. had to pull the engine out and take it apart.
Old Nov 19, 2014 | 07:08 AM
So you used gates belts and tensioners? I was gonna buy the parts off of rally sport direct...Do you reconmmend them or should I go oem?
Old Nov 19, 2014 | 07:09 AM
Gates Timing Belt Kit w/ Water Pump Subaru WRX 2002-2003 TCKWP328A at RallySportDirect.com
What I am thinking about buying.
Old Nov 19, 2014 | 02:05 PM
Brfatal's Avatar
Don't. Use OEM water pump. You can use the Gates belt.
Old Nov 19, 2014 | 07:00 PM
Why not? Thought OEM was the best? What other options do I have?
Old Nov 19, 2014 | 07:55 PM
Just seen that period. Thanks
snowflow
Feb 15, 2009 08:30 AM
Slack
Apr 18, 2005 04:29 PM
dorifto88
Dec 20, 2002 11:27 AM
