need help turbo flutter
Old Sep 26, 2004 | 05:09 PM
HYPER WRX's Avatar
Car Info: 2003 impreza wrx
i need help my turbo is fluttering at low boost if i push my car it doesnt do it i dont know if my hks ssqv bov is broke and thats what is causeing it any one have any ideas i cleaned the bov checked all hoses and the only thing i can think of is the bov is not working as it should i works at high boost not low boost
thanks in advance
Old Sep 26, 2004 | 05:38 PM
soggynoodles's Avatar
what other mods do you have?
U-pipe? D-pipe?
Might be the wastegate flutter, normal if don't have cats.
Old Sep 26, 2004 | 05:45 PM
HYPER WRX's Avatar
i have utec uppipe turbo back hks bov intake mbc pullys all have been on the car for well over a yr and its just happing now i dont understand it could it be the wastgate not working right or the bov i ahve no clue
Old Sep 26, 2004 | 05:53 PM
are you still boosting the same as before?
Check your boost guage and see if your psi's #'s are off.
might want to check this link out.
http://www.clubwrx.net/forums/showth...hlight=flutter
or do a search for wastegate flutter.
Old Sep 26, 2004 | 06:17 PM
HYPER WRX's Avatar
boosting the same from what i can see
Old Sep 27, 2004 | 02:57 AM
kettsupp's Avatar
i think it might be your bov..i had a bov on my car..and it would flutter because the spring was too hard..try and put your stock bov back on..that's what i did and the fluttering went away..and stock bov is the best because recirculation is the best!! and it could hold up to 18 psi
DarkJuic3b0x
Aug 7, 2011 03:00 PM
sanjosuby
Dec 2, 2010 05:20 PM
sanjosuby
Dec 2, 2010 02:05 PM
insaners
May 4, 2004 12:39 PM
phwishpow
21
Nov 4, 2003 10:22 PM
