Need Help / rattling noise
Old Aug 3, 2007 | 01:03 PM
sylencce's Avatar
Car Info: 04' WRX Silver Scooby
Any help with this is appreciated and I'll try and put as much detail in this as possible.
When driving and when i'm on the accelorator, between 3K and 4k rpms in 2nd and 3rd gear, i'm getting like a sputtering or slight rattling noise. I checked my exhaust, down pipe and up pipe and everything is tight. I even had my local shop check those out on the rack and everything is tight.
Any suggestions or if anyone has any ideas i'm open to it, but my next and last step is the dreaded dealership!!
Old Aug 3, 2007 | 07:30 PM
DemonPossessed's Avatar
Car Info: 05 wrx
rattle
it could be the heat shield on the uppipe. to check just reach in and try to jiggle the uppipe shield
especially sti uppipes the welds break
good luck
Old Aug 3, 2007 | 08:19 PM
Car Info: 05 wrx
rattle
double post
Old Aug 4, 2007 | 09:12 AM
sylencce's Avatar
good luck
I checked that because I used to have that problem when I put in my Cobb Heat Shield but it's solid.
It's weird, it seems to be loudest after the car has been running for a little bit but it's not affecting the performance at. I have no boost leakage, no exhaust leak and the car runs great.
Old Aug 6, 2007 | 11:30 AM
sylencce's Avatar
Bump, anyone got any ideas on this one?
Old Aug 23, 2007 | 07:17 PM
dynamic_klink's Avatar
Car Info: 2005 Honda Civic
had a car come in today at work because of a rattling noise at around 4k rpm. i'd say just rack it again and bang on the heat shields to check to see if they make contact with any part of the exhaust. either that or raise it up, throw it in neutral and rev to the rpm that you hear the rattle while someone stands underneath and takes a look. most likely it might be a heat shield that's a little too close to an exhaust pipe.
Old Aug 23, 2007 | 07:18 PM
if that doesn't work then that noise might be coming from the trans considering it's in 2nd and 3rd gear, maybe something loose in there?
Old Sep 2, 2007 | 10:46 AM
JDMWrx04's Avatar
Car Info: subaru wrx 2004
it sounds like wastegate flutter to me. When you are at 3k or so rpms the wastegate will open a little and it will tick or make a rattling noise and it gets very annoying. This happens when you have an aftermarket cat back exhaust or any type of exhaust mods. To fix the problem tighten the wastegate arm a turn or 2 and that should take care of it.
pwnx0rz
Nov 20, 2007 05:13 PM
Boosted03WRX
Feb 26, 2004 11:34 AM
NJ Dino
Oct 19, 2003 01:08 AM
Cend_wrx
Feb 6, 2003 02:30 PM
STiNightFall
Dec 14, 2002 01:12 PM
