more noises!!!!!
Old Oct 18, 2004 | 08:01 AM
joltdudeuc's Avatar
Old School
Car Info: '99 RBP GM6
Center Defferential.
This can be damaged by either running different size tires/wheels that result in different overall diameters OR from excessive use of the hand brake while driving, which makes the front wheels turn while the rears do not.
These will damage the center diff. Another way is to change the rear differential and not have correctly matched the gear ratio to the transmission/center diff. OR having put in a different transmission who's ratios were not made for the current rear diff on your car.
Front diffs are mounted to the transmission/center differential in case you were wondering.
Now, you should really get this to a performance automotive shop near you. There should be some quality shops in Britian whom specialize in subarus. They will be able to diagnose your car.
-Gagan
Old Oct 18, 2004 | 08:03 AM
joltdudeuc's Avatar
Old School
But you know what... It could be just age. The more mileage gets put on the car, the more noise it will make.
Get it looked at, and you should find your issues.
-Gagan
04caliwrx
116
Jan 12, 2012 03:36 PM
Speed Element
Engine and Drivetrain
May 13, 2010 11:10 AM
StlWrx
May 11, 2003 04:29 PM
akordun
Mar 23, 2003 05:42 PM
2000RS
Feb 1, 2003 02:40 AM
