MBC used as restrictor pill...
Old Oct 6, 2006 | 11:52 PM
jahl7787's Avatar
Car Info: 2003 WRB WRX
Question MBC used as restrictor pill...
I have read a little on a mbc being used instead of the factory restrictor pill in the hose coming from the turbo outlet. Anyone know if this works? I am wondering if doing so I could still effectivley raise the boost while not having the dreaded pt/fb associated with mbc's. Also, can anyone tell me if the pill is needed when using a mbc normally? I have used the hose from the turbo to the mbc without it, and had no problems, but read somewhere its still needed? Anyone?
Old Oct 7, 2006 | 11:34 AM
testes1010's Avatar
if you want to affectively raise boost, safely. Get a CobbAP. PTFB is not the ONLY issue with MBCs.
Jeremy
Old Oct 7, 2006 | 11:41 AM
thekid925's Avatar
Car Info: 05 obp sti
Jeremy
what he said, get a CobbAP
Old Oct 7, 2006 | 06:06 PM
jahl7787's Avatar
So, does anyone know? I am fully aware of mbc's and the negative effects on the motor, so please help if anybody can answer my question. I'm not about to spend 600 bucks on an ap yet.
Old Oct 8, 2006 | 06:21 AM
testes1010's Avatar
We've answered you, you are not listening.
Raising boost w/o adjusting fuel & timing isn't a safe way of making power.
If you don't want to spend $600 on an AP, look into Enginuity & OpenECU, it'll only cost you ~$90 for the cable & several hours worth of reading to use the software properly.
Theoritically using an MBC as a 'pill' will still produce the same PTFB issues & the CL/OL issues found on the '04-05 WRXs.
The pill is not needed when using a MBC(no matter how much I recommend against it). The pill is used to restrict pressure to the stock Boost control solenoid(BCS). Stock, the BCS is used in a bleed configuration, if the pill was not used in the original way the car would only boost ~7psi(wastegate pressure).
Old Oct 8, 2006 | 01:26 PM
jahl7787's Avatar
NOW you've answered my question, so thanks.
brucelee
Oct 21, 2008 08:01 PM
powerlogix
May 11, 2007 09:30 AM
1sicwrx
Mar 20, 2007 01:01 PM
myroncuz
Hawaii Classifieds
Jan 18, 2007 05:57 PM
cascaritas
Aug 11, 2006 10:47 PM
