Max MPH!!
Old Jan 22, 2004 | 04:29 PM
  #61
GotBoost?'s Avatar
Car Info: 2003 PSM STi
I didnt read all the response, so I apologize if I am repeating anything anyone said.....
that whistling noise (120+ mph) is from the side mirrors....it scared the isht outta me the first time I heard that, but listened real close and found it to be the mirrors....then I looked at the rally cars and saw that their mirrors are shaped differently, I am guessing to cut down on the wind resistance that causes this sound.
As for my top speed....(03 WRX, Stock at the time) I was driving down to Las Vegas really early in the AM (3:30am) and wanted to see what my car could do....lets just say I got up to 135 before I got scared, and the car was still pulling hard. Made me realize that a body kit would really help keep the car planted on the ground at that speed. BTW....the WRX wing (unlike alot of other cars that have wings for looks) actually does work, it was designed to be fully functional. I am not sure on the actual downforce numbers...but I will see if I can find a link about it.
-Ted
Old Jan 22, 2004 | 05:34 PM
  #63
GotBoost?'s Avatar
Originally posted by wrxwagon2b
the Highest I've gotten up to was 135mph on New Years day at 7am. the Roads were damn near empty i couldnt believe it. The car speed up to 110mp like its nothing but then from 120 to 135 it was taking a long time to get up. The mid-Range power is lovely but the Low and High range isnt as strong.
How can you attain better High RPM ummph? I know with an Uppipe, Turbo back, and proper ECU tuning can resovle the low-end going to mid but what about High end?
I guess it depends on how much more top end you want.......I guess the most noticable results would come from either a taller gear set....or a 6 sp. or a combo of the two. Then again, a bigger turbo would also take care of that....VF22 big boy will get you alot of top end as well...see, the problem with the WRX's top end....is mainly because the small TD04 looses its effectiveness after about 5500-5800 RPM, and the boost levels actually drop off pretty sharply. (If you look at a dyno chart from a Stock WRX, you will be able to see this drop).
Weather conditions also make a considerable amount of difference....your car will not perform as well at high altitude, or in really hot weather (heat soaked IC). The density of the charge of air going into the engine will be alot less than on a nice cool day at sea level. (thats why some people use a water spray to keep the intercooler cold, it makes the air more dense, giving you better combustion in the end)
-Ted
Old Jan 22, 2004 | 06:37 PM
  #64
dr3d1zzl3's Avatar
Car Info: 08 sti
Got mine up to at least 150-160 range
Old Jan 22, 2004 | 09:43 PM
  #65
Steppin Razor's Avatar
@Stoptech
Car Info: 2002 WRX Wagon
i've done 187.
Old Jan 22, 2004 | 09:57 PM
  #66
This thread is not in metric units Tim.
Old Jan 29, 2004 | 03:49 PM
  #67
dr3d1zzl3's Avatar
Car Info: 08 sti
lol own3d
Old Jan 29, 2004 | 04:41 PM
  #68
Re: different info
Originally posted by hotrod
BAN SUVS
Well thats interesting.
I wonder where the communication disconnect is, cause you obviously got different info than quickscooby did.
I hate it when two people go to the same vendor and come away with different info.
I guess we'll just have to wait and see if Shiv will jump in here to clear it up, or see if some other user has the same experience of a hard fuel cut at 160 and below boost limit.
Larry
Somehow I missed this before, thanks Dre for digging this up. I don't know where the idea that there is a fuel cut in the Vishnu reflash came from, but I worked for Shiv when that was posted. I stood in the office of his shop and asked him. Hard to imagine any "information disconnects" there.
Old Jan 29, 2004 | 06:44 PM
  #69
awns729's Avatar
Car Info: want a WRX
HAHA! i just got the metric units thing...and ban, you dont work there anymore? what happened if you dont mind me asking
Old Jan 29, 2004 | 06:52 PM
  #70
I got tired of spending $300 a month in gas and bridge tolls, and 2 hours in my car everyday, to commute. I also wanted to go back to school, which I have, and that would conflict.
Old Jan 30, 2004 | 08:23 PM
  #71
Vins02wrx's Avatar
Car Info: 02 blue WRX header,turbo back exhaust,framairfilte
lol I don't know what you guys are smoking but i have an 02 wrx auto true the car has a speed/fuel limiter at 130mph at 5k now that has been hit many times, with both the stock 16s and the rotas17inches and the stock exhaust and the full turbo back exhaust with the header the only difference is the size of the wheel and the rpm when you hit it 17s hit lower roughly 5k 16s i was a little bit higher like 5200k but as far as I know on an 02wrx auto the top speed is limited to 130mph then cuts out and lets you back into it like 120mph.always wanted to know how to cut it out but still warranted so can't really do that hacking yet.
Old Jan 30, 2004 | 09:43 PM
  #72
awns729's Avatar
good luck with school ban suvs
Old Jan 31, 2004 | 01:12 AM
  #73
dr3d1zzl3's Avatar
Car Info: 08 sti
hmm my car is planted at highspeeds with my 17's and no spoiler..
Blah i hate that spoiler it looks like crap...
Old Feb 5, 2004 | 03:23 PM
  #74
4830DeuceWRX's Avatar
Car Info: 2002 White WRX
I have topped out my Rex on my way to my cottage, it when about a cm past the 140 on the speedo, I have a few mods so im sure i was doing about 150 or something. I would like to add that in topping out my car i blew my 5th gear synchro. So idk if you guys want to try it.
Old Feb 5, 2004 | 03:44 PM
  #75
SF miami WRX's Avatar
Car Info: silver MIAMI wrx in the bay area
135
skoobywrx
Feb 27, 2003 08:38 AM
Ichiro
Jan 10, 2003 01:13 AM
FW Motorsports
Dec 6, 2002 02:49 PM
