Lower PSI, Uppipe Leak?
Car Info: 2004 wrx
Cobb Stg 1 (resetted), recently installed a catless perrin uppipe, from 14.3 PSI now only hitting 13.0PSI... Most likely a leak?
very possible, but also consider you are running a mod that is not 'tuned' into the map, expect the unexpected when doing so.
more than likely its an preturbo leak from installing the uppipe, just get back under it & retorque everything.
bigdaddy
Jul 10, 2003 12:09 PM
