Knocking ? ! ?
Old Oct 9, 2005 | 10:25 PM
ScOoBy RoO's Avatar
Car Info: 2004 World Rally blue WRX
Knocking ? ! ?
i was lookin at a couple posts and what does this mean ? can anyone help ? sorry im a noob
Old Oct 10, 2005 | 05:33 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Knocking is when your car detonates or "pings" due to improper air fuel ratio or timing. In other words if you car is not tuned right for the mods you have your car may knock/ping. Bad gas or gas with lower octane rating then your ECU mapping requires can also cause knock.
Old Oct 11, 2005 | 10:12 AM
dubRexer's Avatar
Car Info: white/gold sti
Exclamation and to add...
knocking/ detonation is BAD. can result in a cracked (pick one) - piston, ring, sleeve.. but you'd know if that happened. check your plugs. they'll tell you whats going on with running too lean or rich.. but lean is worse then rich. too rich = loss in power, too lean you'll have power until something breaks!
KurleeDaddeeWRX
Sep 27, 2003 05:00 PM
jumper
Sep 13, 2003 09:35 AM
FinalBean
Jul 22, 2003 03:39 PM
Fast turbo 20
17
May 8, 2003 11:28 AM
