JDM V7 Swap
Old Jul 16, 2007 | 10:15 AM
  #47
iNfEk's Avatar
Originally Posted by dug-e-fresh
Basically youll need to run 8 wires off the B84 ECU plug to the engine bay. It really isn't too bad to do yourself, as long as you make good connections.
Pins youll need to insert in the B84 plug (the smallest one on the ECU)
2[W] AVCS R+ Sensor
3[G] AVCS R- Sensor
6[RB] AVCS R+ Solenoid
9[R] AVCS L+ Sensor
12[GW] AVCS R- Solenoid
14[SB] AVCS Shield
15[B] AVCS L- Sensor
16[GB] AVCS L- Solenoid
17[RW] AVCS L+ Solenoid
The "AVCS Shield" is basically a ground.
def
This is a really old thread but has useful information to me.
I'm getting a V7 Engine and will be using a USDM WRX 03 Bulkhead harness. My understanding from reading this and other things is that it'll be plug and play except for the AVCS part which you've depicted. Unfortunately like most I won't have the AVCS harness (which I'd like).
anyone got a picture of what these sensors look like?
I'm trying to be uber prepared before the engine gets here.
Jon
Old Jul 18, 2007 | 01:44 AM
  #48
iNfEk's Avatar
also is the [b] stand for blue since B would be black? [SB] per the FSM in the wiring section is "sealed (outer)" is that was it means in your post as well? I know you stated that it's a ground.
Jon
Old Aug 12, 2007 | 02:25 PM
  #49
iNfEk's Avatar
I ended up going with IA Performance harness for the AVCS and the job took about 5 to 15 minutes to install.
Jon
PacificLegacy
Aug 26, 2014 09:54 PM
eddiec168
Feb 1, 2010 09:28 AM
SSAUTO D
Sep 14, 2009 12:52 PM
DoomE.Q.
Nov 27, 2003 08:55 PM
Imprezzive
Mar 28, 2003 09:38 PM
