intake air temp gauge
Old Aug 25, 2003 | 02:23 PM
DamnYank!'s Avatar
Car Info: 2003 Silver WRX
anybody have info on what to get for this and how to best set it up? i've looked at a few gauges. Autometer is way too much $ and i don't like the look. Greddy has one in my range but not sure that includes the temp sender/probe and its only in deg Celcius.
What i need to now is a rough idea of what peaks intake temps can hit post-intercooler (prob tap between IC and TB).
thanks in advance!
Old Aug 25, 2003 | 09:47 PM
Peaty's Avatar
This help?
From a Subaru tec manual,
Old Aug 26, 2003 | 04:44 AM
andyhidley's Avatar
Car Info: 2002 WRX
I would assume that you want to set soemthing up and will be looking at it often for a week or so till you get it sorted out.. If thats the case then get an OBDII scan tool and you can watch/measure IATs
Old Aug 26, 2003 | 04:01 PM
Peaty, is the IAT sensor located upstream or downstream of the IC?
Old Aug 26, 2003 | 05:51 PM
Peaty's Avatar
That's a good question, I'll have to check around.
Old Aug 26, 2003 | 07:46 PM
DamnYank!'s Avatar
from what i understand, IAT is in the airbox (more or less) and i'm looking for post-intercooler temps so the IAT is out.
Old Aug 26, 2003 | 08:05 PM
Peaty's Avatar
I think you are right I'm pretty sure this is the IAT
Old Aug 26, 2003 | 08:09 PM
krillz's Avatar
Car Info: black o2 sedan
how is the iat at 240 degrees by the time it gets to the airbox? iy logger shows 80-150
Old Aug 26, 2003 | 08:16 PM
Peaty's Avatar
IAT is in the airbox or essentially ambient temp depending on if you have removed the snorkus, installed a CAI or left it stock. Do you have the intake stock setup?
The 240° shown above is after the turbo charger has gotten ahold of the air. Just by taking air and compressing it you'll raise the temp. Throw in the fact you are routing it through a super hot spot and it gets pretty warm, say around 248-266°F
ghostrr
Mar 9, 2008 12:19 PM
Island Style
May 26, 2006 08:59 AM
snowrx_2
May 1, 2006 09:33 AM
Rhino47735
Feb 6, 2006 07:53 AM
snowrx_2
Jan 8, 2006 06:41 PM
