installed UP/DP/axleback... no difference in performance wtf?
Old Aug 17, 2003 | 05:36 PM
verc's Avatar
Car Info: GT35R, Meth
ok maybe there is. I got a dynomax muffler so my car still sounds pretty stock.
But my turbo still spools up @ 2900-3000 rpm! I got a gutted UP and an HKS DP so I'm running NO cats and there's no spoolup difference?
And I know that there's the factory boost limit, so I guess I won't feel too much difference in 1st gear right? Cause I GTech'd it and 1st gear max was .6 g's, same as before!
help...this is disapointing...
Old Aug 18, 2003 | 11:00 AM
capt'n'caveman's Avatar
Car Info: platinum rex wagon
is that the only data u got to go by? i sure hope not......first gear is not going to be too much of a difference, as it's too short to really do any type of pull
since u have a gtech, have u tried redoing ur acc time? ur hp cal?
also, give the ecu a little time to get use to the mods, or u can do the vishnu reset
http://forums.nasioc.com/forums/show...shnu+AND+reset
Old Aug 18, 2003 | 11:14 AM
verc's Avatar
lol ok, so I should Gtech in 2nd gear...hm does anyone have a max G reading for a stock 2nd gear pull by any chance?
yeah I'm gonna try the HP calc, should be interesting. Too bad my friend borrowed my gtech to use in his celica alltrac
Old Aug 19, 2003 | 01:23 AM
islandx's Avatar
give it a few days, ecu should "relearn" and produce more power
Old Aug 19, 2003 | 11:44 AM
ScoobyBoy's Avatar
you sure there isnt any leaks? i have an up pipe and noticed a difference right away. and with the downpipe installed you should be ready to boost within seconds. check for leaks. it just doesnt sound right.
Old Aug 19, 2003 | 03:29 PM
verc's Avatar
hm how do i check for leaks?
My exhaust sounds pretty mean right now
well in terms of spooling up yeah with the catless setup if I'm @ >3000 rpm and floor it zoom, 16 psi in a second. However i was under the impression that it would spool up at a lower rpm, like @ 2500 or something
Old Aug 19, 2003 | 07:45 PM
ScoobyBoy's Avatar
listen for a shrill noise when you start up the car. its very distinct, you wont be able to miss it.
the uppipe alone should make your spool time lower. the downpipe should do the same as well. although ive read that the hks dp is a shoddy one, i doubt it would have too much of an effect. a catless downpipe should some improvements regardless.
who did the install?
Old Aug 19, 2003 | 08:44 PM
verc's Avatar
Gruppe-S, who are da man! So it spools with quicker throttle response, not lower rpms then?
jaydm73
Jun 8, 2007 12:52 AM
constellation
Oct 15, 2004 11:59 AM
sssp
Jul 6, 2004 02:32 PM
blackwagonrx
Feb 5, 2004 11:21 PM
blackwagonrx
Feb 5, 2004 06:10 PM
