IHI VF34 Turbo
Old Jan 9, 2004 | 12:22 PM
international B's Avatar
Chewwwwy
you will need larger fuel injectors, a larger fuel pump, and some thing to control the larger injectors. (utec, reflash etc)
Old Jan 9, 2004 | 01:25 PM
Daredevil's Avatar
bigger fuel injectors (sti pink injectors work great), larger pump (walbro pumps are goood) and some tuning or reflash
and a bigger i/c would be good to have too, but not completely neccessary
Old Jan 9, 2004 | 02:11 PM
RussB's Avatar
Car Info: $200,000 sports car
to run an "off the shelf" map from a tuner, you will need bigger injectors, bigger pump, and reflash. You may also want to install an up-pipe and down-pipe in the process.
you *can* run the VF34 with the stock injectors and fuel pump, but it's much harder to tune for, and no tuners have an "off the shelf" map for this setup.
Old Jan 9, 2004 | 02:51 PM
Daredevil's Avatar
ya, i assumed he already had up and down pipe
wrecks43
25
Dec 1, 2006 05:17 PM
subiedave
Sep 19, 2006 07:40 PM
PogiMarky
Oct 20, 2003 12:36 AM
mkewrx
Sep 25, 2003 03:19 PM
johndoe
Sep 4, 2003 03:55 PM
