I got beaten by a (Cobb) Stage 1 :(
Old Jun 14, 2005 | 06:34 AM
BlueREX04's Avatar
Car Info: 04 WRX WR Blue
Originally Posted by Chrisnonstop
Bigger rims will definately slow you down. Especially 18's. Those extra few pounds and rotational mass at each corner will make your car feel as if it's driving through mud. Try switching to a 17" rim if you're into racing. I noticed a difference when I went to my 17" rota attacks. The car felt a little less quick off the line. BUT, the pay off was the massive improvement the wider tires made in the turns....with minor suspension and tire moddification our cars stick like glue to the road....As far as straightline (drag racing) traction,...we have AWD, use the skinniest, lightest tires/rims you can get away with (if that's your thing).
I have worked for Sears Autocenter and been a tech for almost 15 years. Going from a 16" to an 18" is a definate difference in weight (unsprung weight).
I would agree the wheel weight would cause loss of power or the feeling of losing power since you are pusing the car harder than you would have the stock wheels.
And I also thought that someone mentioned if everything was the same except for the cob stage 1 , 2...
Old Jun 14, 2005 | 08:03 AM
mmboost's Avatar
Huh. Stock 16x6.5s are 22lbs I think. My 17x8s are 15lbs. Looks like my bigger wheels actually sprung that unsprung weight, eh?
Old Jun 14, 2005 | 09:27 AM
BlueREX04's Avatar
Yes the wheels may in fact be lighter but he tires are the brunt of the weight, then comes the wheel weights.
Unsprung weight (http://www.musclecarclub.com/library/tech/weight.shtml)
An important concept is "unsprung weight." This is weight that is not supported by the suspension of the car. This usually includes the the weight of the wheels and tires as well as a percentage of the weight of the suspension itself, including control arms, anti-roll bars, shocks, and struts. Reducing unsprung weight is the key to improving handling. The lower the unsprung weight, the less work the shocks and springs have to do to keep the tires in contact with the road over bumpy surfaces. An easy way to reduce unsprung weight and improve traction is to replace stock wheels and tires with special lightweight wheels. Note that as the wheel diameter or width increases, the weight of the overall wheel and tire package increases, thereby increasing unsprung weight.
Old Jun 14, 2005 | 10:19 AM
GEARHEAD's Avatar
oem 16" wrx wheels are 16.5 pounds
srbaugust
15
Jun 2, 2013 02:02 AM
9Vapors
Feb 17, 2006 08:09 PM
gbmotorsports
Dec 22, 2005 05:53 PM
sjt
Nov 25, 2003 10:01 AM
MidniteBlakRex
Jun 10, 2003 05:01 AM
