Hydrolock Help
Old Dec 22, 2014 | 10:04 AM
norcalbro's Avatar
Car Info: 2010 swp WRX hatch
Damn. Sorry to hear this happened to you. Wish I had some words of wisdom for you...
Old Dec 22, 2014 | 12:05 PM
de_engineered's Avatar
Thanks man. I've gotten some decent advice from others here and elsewhere, but lesson here for everyone is don't bother with cold water, I mean air intakes
Old Dec 22, 2014 | 04:28 PM
ddavis's Avatar
Car Info: 04 wagon
Your engines spinning, it sounds like your just not getting spark. I know you said you swapped plugs, but are you checking for spark? Double check that your actually getting spark by grounding it while someone else is turning the engine over. I would even try a little starter fluid to see if you can get it to cough over to burn the junk out.
Old Dec 23, 2014 | 08:08 AM
Lemme give that a try...high hopes.
Old Jan 8, 2015 | 06:55 PM
So...
Tried cranking it again tonight. No dice, but after I had taken out the intercooler (am selling that), I just wanted to see what would happen if I tried tuning it on, and it did cough again, briefly, and more so than the last time I got it to do that.
Afterwards, I saw some crap in the compressor outlet: light brown water, little cheese flecks, not sure how else to describe it. Water and oil emulsion?
There also was a fair amount of water that was not there before that spilled out of the TMIC after I pulled it off. Previously, I had dried it out completely.
Gonna disable the fuel pump and crank it some more, see what else comes out.
Also interesting: the lights flickered in time with the starter when I first tried turning it on. Got better then second time around. I've never had that happen. I'm wondering is this isn't just an electrical issue.
And yes yes, I need to check the plugs for spark still. Saturday...
neo2983
Dec 5, 2007 07:11 PM
brianrwrx03
Sep 25, 2007 09:36 AM
SONofSAM
Nov 3, 2005 09:30 PM
subaru boy
Nov 8, 2004 10:27 PM
mrruins
Dec 8, 2003 01:14 AM
