How to throttle?
Old Oct 29, 2003 | 07:32 AM
John #555's Avatar
Car Info: 02 WRX
FYI, i dont have MBC, but have done the restrictor mod.
when I keep it at 50-75% throttle from low rpm, around 2k rpm, there's noticeable surge that starts at around 2.8k - 3.3k rpm. i'm sure most of you have felt that switch over when riding your WRX. if the stock boost gauge is any indication, by the time the engine spins from 2k to 3k rpm the turbo should be spooled up. One thing for sure is that when i keep it over 3k rpm when cruising, the throttle becomes VERY responsive (no turbo lag) hence I mentioned 3k rpm.
this thread turned out to be very informative! thanks for contributing, everyone!
Old Nov 30, 2003 | 06:51 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
That's the point. The stock ECU limits boost to ~7-8psi at anything under 70% throttle and also runs in closed loop up to this point. Once you're over 70%, the ECU switches to open loop fueling and makes full boost. The problem with an MBC is that it has no problem making much more than 7-8psi at <70% throttle but the ECU stays in closed loop anyway.
-- Ed
Old Nov 30, 2003 | 08:22 PM
Br1t1shguy's Avatar
Car Info: 02' WRX
It's called flow velocity. Suck air through a straw, it comes out fast, but you cant get much air through a straw. You technicly want to open the throttle only wide enough so that the engine can get the air it needs. On a turbo car this really doesnt make much difference, but I guess below boost it might make a tiny difference in felt acceleration.
If you want to actually feel this effect, ride a modern 4 cylinder crotch rocket with ITB's. If you're trucking along at mid RPM and crack the throttle wide open, the engine will bog and sputter, but use the right amount of throttle and you maintain flow velocity through the throttle body's thus achieving much better cylinder filling, motor will come back to life. ITB's really amplify this affect, but it's still a valid theory in plenum based IM's or turbo cars, even if it has a much smaller felt effect.
Electronic throttle cars automaticly regulate throttle plate position to maintain this effect, and alot of new bikes have a second set of throttle plates that adjust their position automaticly so you cant kill the flow velocity when you go throttle happy.
EtchyLives
Mar 21, 2003 07:25 PM
paulnose
Wanted
Feb 12, 2003 05:37 AM
Imprezer
Jan 2, 2003 07:56 PM
AntiochCali
Dec 24, 2002 08:45 PM
scotty305
Dec 16, 2002 04:15 AM
Top
