How to throttle?
Old Oct 28, 2003 | 11:32 AM
phucvtec's Avatar
Car Info: 2003 Subaru Impreza WRX
Question How to throttle?
Ill start by saying that Im sorry if the answer to my question is posted all over these forums... I just could not find it with the searches I did.
My question is, what percentage of wide open throttle will generate the most acceleration? I notice that when Im just casually driving, Ill often take off hard and then lose power as soon as boost starts to spool up (around 2500 rpms). In an opposit scenario, when Im trying to get the maximum acceleration possible, I tend to pretty much depress the throttle close to 100%, which does NOT seem to produce the optimum results. I usually find that somewhere between 50-75% wot is best for acceleration, depending on the rpms.
I know this question is vague, but what Im really looking to find out is if there are any better ways to throttle without just jamming the long skinny peddle to the carpet
Thanks!
Old Oct 28, 2003 | 11:39 AM
MOG_22's Avatar
How can you lose power when boost hits? WTF is wrong with your car. WOT 100% is always best for accleration unless you're bogging or some sh*t. Drag racers put the petal to the metal..
Old Oct 28, 2003 | 12:33 PM
phucvtec's Avatar
How can I lose power when boost hits? I have no idea, but if I keep the throttle depressed at the same level, the acceleration does not increase (volicity keeps increasing, hence acceleration is remaining the same).
As for WOT, I was under the assumption that the computer runs a preprogrammed open loop for WOT, which might mean that you do not get the optimum acceleration.
This is part of the reason that people who use an air/fuel controler such as the Apexi S-AFC set their low throttle setting to like 25% and their high setting no higher than 80%. Above that and it makes no difference. The ECU takes over and no longer makes adjustments based on MAP or MAF sensor readings.
Old Oct 28, 2003 | 01:15 PM
serrano's Avatar
sounds odd. are you downshifting?
Old Oct 28, 2003 | 04:02 PM
Choku Dori's Avatar
Car Info: Corvette Z51
Not an insult, but are you driving an AT?
Old Oct 28, 2003 | 04:56 PM
MOG_22's Avatar
I was under the impression of more throttle=more gas used=more power produced=faster acceleration
Old Oct 28, 2003 | 06:17 PM
Big_DeWeY's Avatar
Car Info: Silver 02 WRX
clutch?
Old Oct 28, 2003 | 11:46 PM
John #555's Avatar
Car Info: 02 WRX
phucvtec,
I've seen similar situation in my 02 WRX. My short answer is keep the rpm above 3k for best acceleration, and dont bother trying to find the ideal throttle position at differnt rpm I tend to shift at between 3.5-4k normally. (it's a tiny 2.0L motor after all)
FWIW... when you WOT at lower rpm especially in lower gear (1st or 2nd) I think the turbo is having a hard time trying to build the boost while the engine rpm is building up. i.e. it's not spooling fast enough to keep up with increasing rpm. you'll definitely have better response if you're already cruising at above 3000rpm, then WOT since the turbo is sufficiently spinning at higher rpm. Even then, I prefer 'squeezing' the throttle than stomping.
Also, there's some truth in "partial throttle is better than WOT at lower rpm". I remember reading about how throttle-by-wire effectively pulls back to adjust when you WOT at lower rpm.
btw, have you done the grounding mod? I highly recommend it for better throttle response! and it's cheap to do!
Old Oct 29, 2003 | 12:06 AM
John #555's Avatar
Car Info: 02 WRX
Originally posted by HTM WRX
in theory on an n/a engine, this could be true. cause in a n/a engine, flow and momentum of the air are the most important. at certain rpm's the flow would be better w/ a lighter throttle position. This only works in cars w/ no intake manifold butterfly's that open at WOT.
HTM,
you actually sound like you have some experience, unlike me... i just read about it I actually read about the throttle-by-wire in an article about Audi S4 and RS4 which are both turbo charged. Would you say that what you mentioned could be applied to turbo cars as well?
Old Oct 29, 2003 | 03:05 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
What mods do you have? If you're running an MBC its quite dangerouse to push the car at heavy part throttle as the ECU doesn't always switch to open loop causing a lean condition which is very dangerous.
That said, I have also fealt what you're talking about. Its mostly if you go WOT at lower RPMs and very suddenly. When you do this, you feel pretty much the most lag the car can ever have as the engine is barely in spool-up range and the turbo is close to stopped. This also puts a lot of load on the engine and causes the ECU to run rich open loop fueling even while the engine isn't under boost. This deffinately makes it feel sluggish. When you roll into the throttle, you're staying in closed loop (more effecient) longer and giving the engine and turbo a bit more time to spin up before you request full power. That generally makes for a smoother, stronger feeling transition.
Just be careful if you have an MBC!
-- Ed
Old Oct 29, 2003 | 07:17 AM
phucvtec's Avatar
Ladies and gentlemen, thank you very much for all of your suggestions!
To answer a few questions: I have a manual transmission. My vehicle is a 2003 w/ about 15K miles. A recently installed boost gauge suggests that boost climps and peaks at about 3200 rmps at ~15psi. My only mods are a Vishnu single dump turbo back, and a GFB BOV (for vanity). I am NOT running a MBC or EBC. I am scared "blank"less of altering my boost for fear of damaging the engine (and making monthly payments on a car I do not drive). Im currently waiting for my ECU to return from Cobb w/ a stage 2 reflash.
This all said, I think that all of your explanations are excellent. The one that probably most applies to my situation is the one where I attempt to accelerate in a certain gear (say 3rd) from a engine speed that is NOT generating peak boost yet, like 2500 rmps. I know the right thing to do is to simply down shift, but I just thought it strange that whenever I hammer the throttle, the car seems to simply bog down and do nothing for about 1-2 seconds. Now, the rich run situation best explains this problem IMO. Makes perfect sence. Im sure this is a situation where slowly depressing the throttle makes most sence.
Anyway, my problem is not a problem, rather a curiosity. I try to learn the most about the vehicle that I drive, not just because of my curiosity, but because I think its my responsiblilty My vehicle runs fine. I have absolutely no problem eating randon civics that tool around my neigherbood. AWD is simply unbeatable
Thanks people
Top
