How many bottles of motor oil ('04 WRX)
Old Sep 22, 2004 | 04:09 PM
Jumpman23's Avatar
Car Info: 2004 PSM WRX
how many bottles of motor oil "Mobil 1 5w-30 Synthetic" will it take to fill up when changing oil ?
Old Sep 22, 2004 | 04:49 PM
surfer5567's Avatar
i put 5 in mine and it was maybe a little high. i mean a little.
Old Sep 22, 2004 | 08:08 PM
RussB's Avatar
Car Info: $200,000 sports car
assuming you're talking about a WRX, it's 4.8 quarts.
Old Sep 22, 2004 | 08:47 PM
nic3krnnamja83's Avatar
can we say wrong section? lol this is engine managment, ur probably thinking managing an engine, no sorry this is tuning stuff. probably maintenance or powerplant will do u better. can understand the confusion tho
Old Sep 23, 2004 | 05:52 AM
Wingless Wonder's Avatar
Thanks, I've moved the thread to the proper forum.
Jumpman23, your Owners Manual contains this information also - look in the index under 'Capacities'.
When you find the time, it's not a bad idea to read the Manual from cover to cover. Yeah, some of the info is common sense but there are a few things in there that are good to know. For instance, sometimes folks unknowingly bump the switch on the top surface of the steering column and then can't figure out how to turn off the parking lights.
Old Sep 25, 2004 | 07:13 PM
5.0 quarts is probably okay for the engine oil capacity but I put in the recommended 4.8 quarts for the WRX, myself. Use caution when exceeding recommended capacity for crankcase, transmission, or rear differential.
Too high an oil level can cause aeration of the oil as the fluid is whipped by rotating parts. You don't want aerated oil to be picked up by the oil pump because bubbles reduces the oil's film strength at bearing surfaces.
Too high a level can also cause premature oil seal failure, as they are made to operate with just a thin film of oil, not repeated contact with liquid.
Old Sep 27, 2004 | 07:36 PM
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
And remember the turbo will consume oil as time goes by, check the levels every 2 weeks.
Rush
Old Sep 28, 2004 | 02:33 PM
MVWRX's Avatar
Car Info: '05 Crystal Grey Metallic WRX Sport Wagon
...why does subaru say 4.2qts in the owners manual...i just changed mine and used 5, it's not over the full line, but 4.8 sounds like it would be perfect...so why do they say 4.2 in the manual? I don't get it...
Old Sep 28, 2004 | 02:52 PM
WRX Rush's Avatar
Maybe you are looking at a different version, different engine, or (I don't think this makes a difference if memory serves) tranny type. . . But putting in 5 quarts will get a litte over full, nothing dangerous I do the same.
Rush
Old Sep 28, 2004 | 02:57 PM
4.2 quarts is for non-turbo 2.5 liter engine.
4.8 quarts is for turbo 2.0 liter engine.
Look for 'Capacities' in Owner's Manual index in the back of the book.
Old Sep 30, 2004 | 03:30 AM
islandx's Avatar
When changing oil I always put in 4 quarts, drive around, and then check the level. You'd be surprised as to how much oil does not drain out when changing oil. 4.8 quarts is the proper amount if your engine were to be completely drained out.
Lorry
Apr 8, 2005 12:12 PM
SubyPrez20
Jan 13, 2003 05:24 AM
SubyPrez20
Dec 30, 2002 10:08 AM
SubyPrez20
Dec 30, 2002 09:36 AM
