High Idle on Startup?
Old Nov 22, 2004 | 06:26 PM
skrapps00RS's Avatar
Car Info: 2000 Impreza 2.5 RS
Yup my 00 impreza RS does the same exact thing, I believe this is normal and its just your car warming up, but defintely worth a second opinion as I know very little about cars. Also, be care where you post your thread, as this thread will prolly be moved as it doesnt fall under the Tires and Wheels Forum ;-)
Old Nov 22, 2004 | 06:58 PM
BillJC's Avatar
Car Info: 02 WRB WRX
Talking
It's normal.
You might want to post this in the engine section though.
Old Nov 23, 2004 | 07:51 AM
yzercyber's Avatar
Car Info: 03 WRX Sedan MBP/17X7.5 SSR Comps/225 Kumho MX
Absolutey normal.
Sage advice on warming up a car: I've got a 03 WRX Sedan now, but the previous car was a '90 Mitsu Eclipse Turbo which I bought new in '90. I made that four-banger pocket rocket last me almost 13 years and 260K miles. It was running good when I sold it, too. One of the things I did to keep it running so long was to always warm it up (every time) before moving.
On the WRX, I don't drive the car until the temp gauge hits at least the top part of the letter "C" (which indicates "COLD). (Man, I miss temp gauges with number degrees on them!) When the engine has reached this point, the temperature is rising quickly. It would be better to let the car warm up completely, but who has the time?
After that, I don't punch the turbo or run it hard (not over 3000 RPM) for another minute or so, waiting until the temp gauge hits about mid-scale, which is the normal running temp.
I also do a 20-30 second cool down, longer if the turbo was spooling just prior to parking.
Old Nov 23, 2004 | 07:51 PM
HomerJay's Avatar
Car Info: MY00RS25
Wrong section for this post, but, yest this is totally normal. I'm on my second Subaru, and both does the exact same thing. I always warm up my car. You don't have to, you can just not rev your engine past 3500 till it comes up to temp.
Old Nov 24, 2004 | 12:07 PM
Pretty much every fuel injected car should idle at ~1500 rpm when cold, and slowly decrease as the coolant warms up. Normal warm idle is about 650 rpm.
Old Nov 24, 2004 | 06:59 PM
awns729's Avatar
Car Info: want a WRX
My fathers 2.5 cyl legacy actually goes down to ~450-500 sometimes
Old Nov 24, 2004 | 07:02 PM
MonkeyAB's Avatar
Car Info: 2001 Impreza 2.5RS(Ti)
100% normal
Old Nov 25, 2004 | 12:40 AM
GDB-EJ20's Avatar
Car Info: Its a gross polluter : (
my rx-7 idles at 3500rpm.....is that normal?
Old Nov 25, 2004 | 07:19 AM
yzercyber's Avatar
sounds to me as if your RX-7 is acting out in a deviant way and should seek counseling immediately
joltdudeuc
Apr 30, 2007 10:45 PM
stevenkhau
Mar 19, 2007 12:42 AM
fatweesle
Nov 27, 2005 07:26 PM
wrxout
Sep 19, 2005 07:35 PM
NJ Dino
Jan 24, 2004 09:09 PM
