Help...EGT install problems!
Old Jan 19, 2004 | 06:45 AM
Ditty77's Avatar
Car Info: 2002 WRX
Unfortunately, it does sound like the sensor is dead.
You have power.
The needle moves.
The sensor is sounds like it's in a spot to read.
It just doesn't.
Try swapping it out with a new sensor or just return the whole thing to be sure, unless you know someone that can look at it cuz we can't see exactly what you did.
Good Luck
Old Jan 19, 2004 | 01:45 PM
Uncle Scotty's Avatar
If you have the gauge wired so it dimms, that may be the problem.
Old Jan 20, 2004 | 07:38 AM
theworx's Avatar
Car Info: 04 Java Black Sedan
If not, go to Forced Fed Industries in Columbus. They are the closest shop to your area I am aware of that does good work.
-WickedRex-
Dec 18, 2006 06:57 PM
grex767
May 27, 2006 10:37 AM
KmanRuffian
Dec 26, 2003 11:00 AM
jid2
Sep 16, 2003 03:26 PM
spdkills
Jan 25, 2003 03:48 PM
