Lag Mod ONLY?
Old Jan 19, 2004 | 06:19 AM
Wingless Wonder's Avatar
A low-compression 2.0 liter turbo motor is a dog until it gets into boost. There's no getting around it. A free-flowing exhaust helps improve spool-up and all-around power but a reflash (or alternate engine management), with or without exhaust mods, really makes the mid-range torque come alive compared with stock. IMO, a reflash on a stock vehicle is the best value per dollar and the best mod for seat-of-the-pants improvement in driveability.
Old Jan 19, 2004 | 06:49 AM
Ditty77's Avatar
Car Info: 2002 WRX
Good advice, you beat me to it.
(I couldn't have explained it that good though)
Old Jan 19, 2004 | 11:43 AM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
Originally posted by 2RXS
also try the 3/16 inch mod it really does helpa bit and only costs about 60 cents..email me for details or i'm sure there are plenty of link to it on this board..
The 3/16th mod is crap. Don't do it unless you have a boost gauge...it just makes the ECU unable to control the boost properly.
I would say get the reflash for low end. If you're not into that I would get an uppipe/downpipe, but then you run into emissions problems. My old Cobb stage 2 had a great low end, and I hear that stage 1 is just as good, without the high end boost increase.
$400 for a reflash that's a 5 minute install is insane bang-for-the-buck.
Old Jan 19, 2004 | 02:28 PM
Choku Dori's Avatar
Car Info: Corvette Z51
Remove the silencer. It doesn't make a big difference, but it does make the turbo spool just a bit quicker (roughly 500 rpm earlier or so). The boost delivery seems smoother too, since it starts earlier as well.
Old Jan 19, 2004 | 03:11 PM
dropkick_muppet's Avatar
Car Info: '03 PSM Sedan
ported turbo and up-pipe. figure $600 + installation, and you'll have a hell of a lot less lag and spool time. add I/C hoses and a DP, and all of a sudden you have a whole new motor.....
Old Jan 19, 2004 | 05:03 PM
Speed Element's Avatar
Former Sponsor
Car Info: Evo X, 04 STI, 335i, Fit
Pectel ECU with AL should do it for you.
You might want some supporting mods to run it though
Mike
Old Jan 19, 2004 | 05:05 PM
Former Sponsor
Just messing.
Up and downpipe with tuning will help, a lightened flywheel helps the car rev faster thus making it feel less laggy so to speak.
Mike
Old Jan 20, 2004 | 01:51 AM
James-
A reflash can be detected, but with minimal powertrain mods, a dealer would likely never look for it. It's not totally obvious. Also, you can order reflashes on a core exchange basis- you get sent a reflashed ECU, and swap that into yor car, then send back yours. Alternatively, there are some "rental" ecus on the private sale forums that you can work out a borrowing price for.
To improve low end and lag, your best bets are a reflash combined with an uppipe and maybe intercooler hoses. A downpipe or full exhaust will also help, but are more expensive, more obvious to a dealer, and will also make a big difference in top end. The uppipe and reflash will make it feel like you suddenly have a much larger motor pushing that turbo, giving you boost at about 2800-3000 rpm.
I also agree with Mike that a lightweight flywheel is a great mod. However, with labor, it's quite expensive, probably $1000 installed for a flywheel, plus another $350 or so for the stronger organic clutch you would want to go with it.
Old Jan 20, 2004 | 09:51 AM
ride5000's Avatar
Originally posted by MPJ Performance
Just messing.
Mike
..and cheaper, with not quite as much difference (but much better bang for the buck ratio than a flywheel swap) is a lightweight/underdriven crank pulley.
flame on.
ken
Old Jan 20, 2004 | 10:17 AM
Former Sponsor
ride5000 - Not sure about the flame on bit perhaps your used to other boards?
But with regards to the Pulley yep I agree but seeing as running both together throws some strange codes and your eventually going to have to change a clutch anyway you may as well throw in the flywheel then. If you had a pulley already you would have some issues so the flywheel whilst not the first mod I would do would be one I would do when replacing the clutch and after all the subject is about removing lag not what mods to remove lag at any given time.
Mike
T-Will
Jun 20, 2007 09:24 PM
Tommy3rd
14
Apr 25, 2003 05:15 PM
Threeclaws
Mar 12, 2003 11:18 PM
Bone
Jan 16, 2003 04:24 AM
Bernie
Dec 8, 2002 10:39 AM
