HELP CHEck ENGINE LIGHT ON :(
Old Sep 17, 2008 | 08:01 AM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
Why on earth would you run a modified car on the factory map?
What is the code that's triggering the CEL?
Old Sep 17, 2008 | 08:17 AM
Shayhan27's Avatar
Car Info: LUMPY CGM 05 WRX
On my car the o2 sensor is not even plugged in. there is a capacitor you can buy from radio shack. I am not sure what voltage it is but you plug it into the computer side of the connector for the 02 sensor and put some tape over it. This is what works on my 05 wrx. NOTE: your o2 sensor will probably need to be replaced if you run this setup for too long.
Old Sep 17, 2008 | 08:36 AM
Subaru_dude's Avatar
Car Info: BMW 525i E39
i took it to local shop and they pulled the code ... it says that EGT sensor Bank current High. And i just replaced EGT sensor like last year. And there is no problem with the car itself .... engine runs fine .... stoichometric ratio ... no weird smell from the engine.
Old Sep 19, 2008 | 11:12 AM
7thSubaru's Avatar
Car Info: 2001 Legacy Wagon
sorry, I was posting from the iPhone before class, so I couldn't type too much.
Gruppe-S carries both fixes but lists the mechanical fix as being for 2005+ models, and I can't tell from your avatar what year you have but it looks like an 02-03). The electrical fix isn't that hard to do, you just have to unplug the rear o2 sensor, cut the wires, and solder it in. If you're not good at soldering I would have someone that is good do it for you.
Have an 01, with the P0420 code, and I'd like to perform this fix. Electrical - cut the wires and solder the wires together? Directions are not clear. Of course I'm reinstalling the O2 to plug the hole only now it's not connected to anything. Please clarify this fix. The mechanical spacer part I understand - any differences in thread sizes between years?
Nevermind, I've since learned I cannot do the electrical fix since NJ conducts the OBDII readiness test and that fix will cause the car to fail
Old Sep 19, 2008 | 12:53 PM
1sicwrx's Avatar
Is your factory EGT probe being used in the catless upipe??
Old Sep 19, 2008 | 03:28 PM
spelk3's Avatar
Car Info: sold 2012 wrx sedan (sold 02 WRX wagon)
The EGT probe fails in a catless uppipe. Get a 2.2k resistor and plug it in the connector where the EGT probe plugs in.
Racerkid
May 29, 2012 06:16 PM
saab92x
Mar 16, 2009 03:16 AM
06scooby
Oct 15, 2006 10:11 AM
rash
May 17, 2003 12:32 PM
The Works
Dec 30, 2002 08:53 PM
Top
