HELP CHEck ENGINE LIGHT ON :(
Old Sep 4, 2008 | 10:49 AM
Subaru_dude's Avatar
Car Info: BMW 525i E39
Just wandering if there is anyway I can defeat Check Engine light that came on. I was running COBB Stage 2. But I sold my AP and now running without tune and my mods on the car as of right now are HKS up pipe, HKS down pipe << i know. With HKS Carbon Ti Exhaust. Any way that i can make the light go away? .. any HELP appreciated.
Old Sep 4, 2008 | 10:53 AM
VRT MBasile's Avatar
I'm assuming the CEL is the rear o2 sensor? There is both a mechanical and electrical fix. Not sure who sells them anymore.
Mechanical fix is basically a spacer that moves the probe out of the exhaust so it thinks its reading normally.
Electrical fix alters the electrical signal so the computer thinks the probe is reading normally.
Old Sep 4, 2008 | 11:29 AM
there ya go
Old Sep 4, 2008 | 01:52 PM
sorry, I was posting from the iPhone before class, so I couldn't type too much.
Gruppe-S carries both fixes but lists the mechanical fix as being for 2005+ models, and I can't tell from your avatar what year you have but it looks like an 02-03). The electrical fix isn't that hard to do, you just have to unplug the rear o2 sensor, cut the wires, and solder it in. If you're not good at soldering I would have someone that is good do it for you.
Old Sep 4, 2008 | 04:11 PM
^^ thx bro i will go to GST and have em install it for me ... its just that light is so annoying at night time ...
Old Sep 4, 2008 | 06:24 PM
jam007's Avatar
Bro even easier, two spark plug anti-foulers, 5/8'' drill bit. Drill them out with the 5/8 drill bit and screw the 02 sensor into the anti-foulers and the anti-foulers into the down pipe and reset the ECU. Easy day..
Old Sep 4, 2008 | 06:27 PM
pancho's Avatar
Car Info: 2004 wrx granny wagon
i got the same problem will the fixer fit on an 04 sti
Old Sep 4, 2008 | 06:50 PM
wrxisthebest's Avatar
just buy a spark arrestor, this is also known as the spacer.
Old Sep 4, 2008 | 06:57 PM
pancho's Avatar
where can u buy one at
Old Sep 4, 2008 | 07:01 PM
illl try to find it
here
$25
http://www.optionimports.com/o2siadcelfix.html
Old Sep 4, 2008 | 07:02 PM
pancho's Avatar
k thanks o by the way u think any muffler shop sells them
Old Sep 4, 2008 | 07:03 PM
no prob...
Old Sep 11, 2008 | 04:32 PM
my check engine light is still on ... i just put the Helix CEL fix yesterday and drove it for like 5 miles or so and it came back on as i just put together both battery wires to reset the ECU. but the light came on again help ... if any one else knows wat could be wrong with it
Old Sep 11, 2008 | 11:06 PM
gottaWRX's Avatar
Car Info: toaster
any other mods? bov? may be running too lean..... at least thats whats wrong with my car right now and i put stock bov back on and everything is better. if anything just get the code pulled and you'll know what you need to fix.
WES
