GFB stelath fx bov setting question. havin' a problem with venting in 2nd gear
Old Feb 4, 2004 | 01:38 AM
ASpec818's Avatar
Car Info: Audi B6 S4
I currently have the stealth fx set at 100% vent to astmosphere. Everytime when I give it like 50-100% throttle in second gear and release throttle in the 3500-6000 rpm range, the bov sort of stumbles and hesitates to vent. It takes around a full second for the bov to vent after i release throttle, instead of venting immediately after. Is there a remedy for this? This only happens in second gear normally. What settings do I have to toy with? thanks!
Old Feb 4, 2004 | 07:38 AM
wrx10404's Avatar
Car Info: 04' wrx
Re: GFB stelath fx bov setting question. havin' a problem with venting in 2nd gear
How old is it? I have heard that during the winter you might need to oil it every month. There is a thread here. do a search for the bov's.
Old Feb 4, 2004 | 08:25 AM
DizzyWRX's Avatar
I heard that you need to clean it, and spray some lubricant, like WD-40 or such, whenever you're having problems with it sticking like that.
Old Feb 4, 2004 | 10:22 AM
Salty's Avatar
After you re-oil it try adjusting the spring on the top because that controls the speed of venting. If you've lost your instructions email GFB and get some new ones.
eric
Old Feb 4, 2004 | 10:29 AM
AWD 20T's Avatar
Car Info: 2009 G Ride
I used to have the same problem with my GFB 50/50 BOV, however with a little regreasing (Mobil 1 Synthetic Grease), it was good as new, and blew off every time for me... Give it a shot, what's the worst that can happen?
grandmasterchan
Jun 20, 2004 10:49 AM
New2MeSuby
Mar 26, 2004 09:00 AM
jroh_spice
Feb 9, 2004 12:07 AM
SHADO
Nov 24, 2003 09:15 PM
WindingRoad
Nov 20, 2003 07:44 AM
