Stock BOV venting
Old Nov 19, 2003 | 02:35 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
Question Stock BOV venting
Can i just plug the diverter hose and let the stock bov vent into the atmosphere? will this set off a check engine light? the hks bov is on backorder and maybe this will work instead.
Old Nov 19, 2003 | 05:20 PM
zojirushi's Avatar
The car won't idle right, and it will throw a cel
Old Nov 19, 2003 | 05:27 PM
what is the difference between the stock bov and an aftermarket bov? my friend had the hks and turboxs bovs that vented out into the atmosphere and had no idle problems or cel
Old Nov 19, 2003 | 05:49 PM
porkchop's Avatar
Car Info: some silver thing
it'll work just fine, just some stock bov tend to leak or have a weaker spring compared to aftermarket BOVs, but you can plug the recirc hose and vent the stock on to atmo.
again, venting anything to atmo, will cost you to run rich...
Tommy
www.mpjperformance.com
Old Nov 19, 2003 | 08:14 PM
Wingless Wonder's Avatar
Origami posted by WindingRoad
Main difference is that the factory part does not vent anything to the atmosphere. It is sometimes called a compressor bypass valve.
Old Nov 19, 2003 | 08:30 PM
zojirushi's Avatar
ummmmm...
difference is, stock bov vents a small ammount of air back into the intake when your at idle . Aftermarket bov's stay shut during idle. Thats why when u take off the recirculation, the car idles like crap.
Old Nov 19, 2003 | 10:47 PM
ohhh, i didnt know that the stock bov vents a small amount of air while idling.
Old Nov 19, 2003 | 11:08 PM
Uncle Scotty's Avatar
Originally posted by zojirushi
ummmmm...
The difference is that the engine was deseigned to operate with a Bypass valve, NOT a 'BOV'...they are not the same.
The correct valve is supplied by Subaru, and vents metered(by the MAF) air back into the intake to control fueling, and this is why venting this metered air to the atmosphere is not the right thing for the engine.
Why do so many people insist on doing such things to their engines and then wonder why they run like ship?
Old Nov 20, 2003 | 07:44 AM
thanks guys for the info. i'll wait until the hks bov gets here.
is the hks bov really on backorder from japan or is the shop i go to messing with me? i've been waiting for more than a month now.
grandmasterchan
Jun 20, 2004 10:49 AM
New2MeSuby
Mar 26, 2004 09:00 AM
ASpec818
Feb 4, 2004 10:29 AM
sd70feb
Oct 3, 2003 12:43 AM
