gas mileage with sti pinks
Old Dec 8, 2005 | 06:12 PM
stealth_wagon's Avatar
Car Info: 04_wagon_wrx
Is it still possible to get good gas mileage if you upgrade to sti injectors or can you tune your ecu to compensate for the larger flow rates?
Old Dec 9, 2005 | 11:51 PM
maverick707's Avatar
Car Info: 03 wrx
I have pinks, pump, plugs, vf22, cai, bigger top mount, turbo back, ecutek tuning, and usually cruise around at 16psi and I get 19-23 mpg. That's with mon-fri freeway commuting with minor street driving.
Old Dec 10, 2005 | 06:42 PM
Twenty36_1's Avatar
Car Info: soon to be wrx
Do you have any dyno plots of this set-up? I am planning to upgrade to a larger turbo (I assume I have a VF23 on my car. I know it is larger than stock but smaller than the VF34. AND I cannot get to the engravings on the turbo since it came on the car.) I most likely will get a VF22. I am not really interested the dyno plots for the HP, BUT FOR the A/F ratios with those injectors. I have heard they are too small but most people that say that do not even own the VF22. Also what top mount? I currently dynoed 235whp/wtrq (~330chp) on Vishnu's dyno and I want to make about 275-285whp (~380-395chp) on the same dyno. I already have an UP, TBE, Pinks, Reflash (tuned), pulley. I know I will need a larger top mount, but I prefer to not get larger injectors unless they are absolutely needed.
Old Dec 11, 2005 | 10:38 AM
Car Info: 03 wrx
I have a dyno chart, but it was before I got plugs, pinks, pump, bigger top mount, and tuning with that stuff (I had it tuned for what it had). Without the above I dynoed 241whp. http://www.cardomain.com/ride/789035
I'm not exactly sure what I'm pushing, but I'm guessing that I'm near 330 hp (not wheel) because I did a rolling start in 2nd with a newer looking m3 and we were dead even. I also had 2 12s in the trunk and a passenger.
Old Dec 11, 2005 | 06:59 PM
Donkey's Avatar
Car Info: 02' WRX
Are you talking about just changing injectors and nothing else?You need to include more information.
wu!
May 23, 2006 04:28 PM
ZeR0
Dec 12, 2005 09:40 PM
gooder77
Oct 26, 2005 09:09 PM
kidatari
Sep 9, 2004 12:22 AM
Shaitiger
Mar 30, 2003 11:22 PM
