fuel cutting still even with fcd?
Re: fuel cutting still even with fcd?
Originally posted by turbeau
help please my car still hits fuel cut at like 17 lbs with the fcd on why is that please explain thank you,
Beau
Beau
in order to work it must INTERRUPT the MAP sensor signal to the ecu. that means cutting a wire. did you do that?
i do hope you have the proper modifcations to require and successfully use a FCD.
hth
ken
yes i did do that, and i have a fcd cause the stock turbo only runs 12lbs where i live and i wanted 16! because on the fcd there is a setting number 10 for wrx's and i was wondering if it only rose it like lbs to be safe or what? also how much should i be able to run with a fcd
