Frame Cutting
Old Feb 17, 2011 | 06:24 PM
DarkJuic3b0x's Avatar
Car Info: EQ Tuned * Corn Juiced '05 WRX
Frame Cutting
Had some work done to my girl and E85 tuned yesterday by EQ (can't say enough good things about them) but now I have an issue.
My UEL header is rubbing, or will rub, on the frame. Technically 2 sections of the header isn't making contact with the frame but when I'm driving I know they do. The distance beween the 2 sections of the header and the frame is VERY minimal, you could slide a piece of paper in between and that's about it.
I can definitely feel the vibration coming from the header and the frame when I'm decelerating (now that Ed mentions it, I can hear it too) and sometimes when I turn or go from a standstill in 1st, the car vibrates (most likely header contacting frame).
I want to know is there any special steps to cutting a piece out of the frame so the header doesn't rub? I read on iwsti and somewhere else that you have cut a SPECIFIC amount off the frame, not just a big chunk and some detailed steps.
What do you guys think?
Thanks!
Old Feb 17, 2011 | 07:47 PM
xhengmanx's Avatar
hey are you talking about the sub frame? if anything you can remove that. btw what headers did you end up going with? i was at eq today and he told me you changed out the headers and the new one has rubbing issues
Old Feb 18, 2011 | 02:15 AM
Ya think it would be more efficient if I just cut a piece off rather than taking the whole frame off or you think I should just find a shop that could take it off for me?
TiTek UEL header/uppipe. Yeah, nothing big but like I said in the previous post, I can see two sections of the headers where it makes contact with the frame. What you doing there?
Old Apr 8, 2011 | 09:42 AM
Trinidrift3's Avatar
Car Info: 2003 ABP DC5
dont cut your frame. upgrade your motor mounts. upgraded motor mounts are stiffer then the stock ones; this will prevent the motor from moving while you drive so the uel header will not hit your frame and crack
Old Apr 8, 2011 | 10:07 AM
Javirex23's Avatar
Car Info: 07lmtd 6spd wrx eq tuned
Maybe grind it off a bit ti give it more clearence with a dremel or something...my .02
turbeau
Jan 25, 2004 07:00 PM
SF miami WRX
Jun 9, 2003 04:32 PM
BobbyD
Dec 12, 2002 10:54 PM
