FMIC on stock engine
Old Sep 18, 2004 | 07:15 AM
ADIDAS's Avatar
Car Info: 2004 impreza WRX
is it ok to put a FMIC on the stock engine?
Old Sep 18, 2004 | 09:59 AM
awns729's Avatar
Car Info: want a WRX
Yes, but why? There will be more lag and the same amount of power. Wait till ya get a big *** turbo.
Old Sep 18, 2004 | 10:17 AM
Mister 2's Avatar
Yes.
Old Sep 18, 2004 | 02:12 PM
Lowball's Avatar
Car Info: 02Wag on 17's
as said above...yes you can but you don't really need to. If you want a bit more extra cooling then just get a bigger TMIC. With the FMIC it will take you longer to spool the turbo (lag) and cost you two times as much as a TMIC. Plus they are a PITA to install for the most part. You will loose your fogs depending on which one you get and you will have to trim you bumper beam and you plastic bumper cover. Again it depends on which one you get as to how much trimming you will have to do.
If you're not planning on getting a larger turbo plus the extra supporting parts and your not going to be doing any track days then save your money.
The look cool IMO but are not really required, espically for a stock turbo.
Lowball
Old Sep 18, 2004 | 04:41 PM
ADIDAS's Avatar
Lowball
AAAAAh. I didnt know you could get larger TMIC's This is my first turbo car, so I am learning things all over again. Thanks.
Old Sep 18, 2004 | 06:08 PM
awns729's Avatar
Theres no need for an aftermarket intercooler with the stock turbo.
Old Sep 19, 2004 | 01:37 AM
kettsupp's Avatar
very true
Old Sep 26, 2004 | 02:37 PM
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
Work on how much air your sucking in and how much exhaust your car is blowing out before you worry about how dense the air is going into the combustion chamber. Cheers
Rush
PoCkEtRoCKEt74
Hawaii Classifieds
Oct 1, 2011 04:26 AM
JRsWRX
Jul 4, 2007 07:17 PM
XkrazyAsianX
16
Mar 22, 2005 03:13 PM
keirnna
Oct 19, 2004 09:13 PM
sheff
Jul 20, 2004 09:50 AM
