FMIC?
Old Sep 9, 2004 | 01:58 PM
dwrx04's Avatar
Car Info: 98 2.5RS
FMIC?
alright a distant friend of mine told me that he had seen a rex with the intake manifold turned around with a fmic so he would get the bet air flow possible...i almost broke out in hives do to my allergies(i am allergic to bull****)...so when i should him that the intake manifold opening would be blocked by the all important alternator he freicked so i want to make sure im not totally out of line here so maybe if u have seen this done or u also know that this isea is bull**** you can inlighten me.
thanks
dan
Old Sep 9, 2004 | 02:02 PM
Mister 2's Avatar
This was in an issue of Super Street a few months back. From what I've heard the alternator was adjusted lower by using a smaller belt and that it does fit w/ very little clearance. If you look at your intake manifold (top view) you'll notice that it is offset toward the front so if you reverse it then you'll have more room between the throttle body and the alt then it would initially appear. Secondly notice that the throttle body is angled up slightly.
I'm considering doing the same so I'm going to take some measurements between the alternator and the hood to see how much space there actually is.
Old Sep 9, 2004 | 02:39 PM
dwrx04's Avatar
Car Info: 98 2.5RS
hey thanks for the info man...and if u ever end up doin the mod send me some pics i would like to see it
Old Sep 9, 2004 | 03:37 PM
New2MeSuby's Avatar
Car Info: 2007 Mazdaspeed 3, Black, 6spd
I've seen it too. As I understand its only to shorten the pipes from the FMIC. Are there any other advantages that I am unaware of?
Old Sep 9, 2004 | 06:50 PM
Mister 2's Avatar
Originally Posted by Git-R-Dunwrx
what issue of superstreet was this? i want to check this out for my self...
David
Its the issue w/ the white/pink RX-7 and RX-8 on the cover (July, I think)
Old Sep 9, 2004 | 06:52 PM
Mister 2's Avatar
Nope, that's it.
Old Sep 9, 2004 | 08:10 PM
Wingless Wonder's Avatar
Origami posted by dwrx04
Imprezer's car pics, with shot of engine with reversed intake manifold.
Technical details on his CUSCO demo car.
Old Sep 9, 2004 | 08:14 PM
Besides creating a shorter path for the intake plumbing, there may be some benefit to keeping that same intake tubing clear of the turbo, if it's still in the stock location. Less heat soak although it isn't as much of a problem as heat soaking a TMIC since it's thinwall tubing versus the mass of an IC.
Old Sep 9, 2004 | 09:39 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
There isn't much tech info in my post yet. Haven't had time.
Old Sep 9, 2004 | 10:15 PM
dwrx04's Avatar
Car Info: 98 2.5RS
thanks for the info. is there any issue with the throttle body linkage and such be cause it looks like a biatch and a half and all that work and you could just keep the tmic to shorten the turbo to ic length...seems like a whole lot for nothin then...thanks for the help though
dan
btw ur car is badass...now u just need a woman...jk later
PoCkEtRoCKEt74
Hawaii Classifieds
Oct 1, 2011 04:26 AM
JRsWRX
Jul 4, 2007 07:17 PM
XkrazyAsianX
16
Mar 22, 2005 03:13 PM
keirnna
Oct 19, 2004 09:13 PM
sheff
Jul 20, 2004 09:50 AM
