fluttering noise?
Old Nov 4, 2003 | 12:54 AM
Darknight's Avatar
Car Info: 2002 Black WRX
fluttering noise?
Does anyone know what causes that fluttering noise when I am at full boost? (18 psi) All started when I installed ebc. (Greddy Profec B Spec 2)
Old Nov 4, 2003 | 12:56 AM
international B's Avatar
Chewwwwy
i hope you are not running 18psi on stock turbo... if you are TURN THAT ISH DOWN to about 15.5-16psi. that fluttering noise could be a # of things. most likely wastegate flutter, or the solinoid of the boost controller it self.
Old Nov 4, 2003 | 01:01 AM
Darknight's Avatar
I'm running a turboxs stage 4 fmic on my car. Sounds like it may be my wastegate. Is it normal to have that fluttering sound?
Old Nov 4, 2003 | 09:58 AM
Chewwwwy
yeah, flutter is normal. what turbo you using?
Old Nov 4, 2003 | 06:07 PM
Darknight's Avatar
I'm using a vf34 turbo.
Old Nov 4, 2003 | 10:00 PM
huck's Avatar
Car Info: 2013 GR STi
I just installed my new intake and discovered the exact same noise. Scared me for a few minutes until I figured out what it was. It is semi annoying though. Is there anyway to get rid of the wastegate flutter noise?
...other than welding it shut. :banana:
jinorazi
Jun 8, 2008 01:53 PM
djtmalta
Aug 14, 2005 12:02 PM
Jizzo_02SubiWRX
Jun 7, 2005 10:20 PM
Normie J
Jul 15, 2004 07:58 PM
hezlok
Jul 2, 2004 10:18 AM
