Final Decision
Old Jun 8, 2004 | 10:49 AM
chicote's Avatar
Car Info: 02 wrx wagon
thats a lot of stuff!! =)
Old Jun 8, 2004 | 10:54 AM
JDM_SAL's Avatar
From: Your friendly neighborhood Marine Corps recruiting station! (Pearlridge Mall by Banditos)
Rob any banks lately?
Old Jun 8, 2004 | 08:26 PM
Damaged Goods's Avatar
Car Info: 04 wrx
a little off topic, but what does having the wheel clipped on your turbo do anyway?
and how much is deadbolt charging you for there services?
Old Jun 9, 2004 | 11:35 AM
SilverScoober02's Avatar
From: Detroit, Where the weak are killed and eaten...
Car Info: 02 Impreza WRX Sedan & 2008 GMC Sierra 4x4
Ah what it would be like to have a ton of money to spend! I am envious!
Good luck with the car!
Old Jun 10, 2004 | 08:57 PM
Lurk's Avatar
Your engine management setup sucks. And our cars use direct coil ignition. No MSD system will work. And why do you want a Bee*R misfiring system? Sounds like you read alot of Super Street.
Old Jun 11, 2004 | 04:03 PM
Lurk's Avatar
I ran piggybacks too for a while, but I got tired of the stock ECU learning around the settings within days. I mean, if you want to reset your battery every week then that's cool. But FYI, once you boost past 17PSI or so with the stock ECU you'll trigger a CEL, and end up losing power. If you really want to take full advantage of that VF22, you'll need either a reflash or a standalone. Sounds like you got some money, so why not just get a custom programmed Motec?
Old Jun 12, 2004 | 02:49 PM
My_Red_Suby's Avatar
Car Info: 2005 Metallic Gray STI
Ecu...
For now I'm going to use piggy back systems with my ECU. In the near future, I'm definitely getting the HKS F-con V-pro Standalone Fuel System once I replace the internals of the engine....
MArky
Old Jun 12, 2004 | 03:32 PM
Lurk's Avatar
F-Con V won't work with the US-spec wiring and sensors. I wanted the Mines VX-ROM for my car, but JDM standalones don't work on our cars.
Old Jun 12, 2004 | 05:20 PM
Ecu
I spoke to an HKS spokesperson and he said that a USDM Spec F-con is in the works right now. Besides that, I'm gonna need a good tuning shop in the greater NJ area to tune my car...
Marky
REXYBoi
Feb 7, 2004 08:09 AM
DrVortex
Feb 1, 2004 10:23 PM
CRAWLWRX
25
Jan 25, 2004 09:42 PM
Gixxer1000
Jul 31, 2003 12:41 AM
