Engine ticking when warm.
Old Mar 31, 2004 | 06:28 AM
wrx21's Avatar
Car Info: 2004 Impreza WRX
I'm guessing by your name that you are an X 4G63 Driver like myself. That engine basically has the same hydraulic lifters that the WRX has. The 4G63 would tick on a could startup because the oil was cold and thick and woul sludge up inside the lifters. I dont know why the WRX would be any diferent. Sounds like it may be more of a problem. Now I'm curious why it would do that too.
Old Mar 31, 2004 | 08:49 PM
Wingless Wonder's Avatar
WRX EJ20 turbo engine has solid lifters and periodic lash adjustment is performed using shims of varying thickness.
As for the ticking sound, my rex ticks when warm. On some cars, it's more noticeable than others. Maybe my car's valve lash is out of spec...
Old Apr 1, 2004 | 09:25 AM
wrx21's Avatar
Really .. I thought I read somewhere that WRX's have Hydraulic Roller Lifters. I'm probally wrong though. Haven't had a chance to tear into this engine yet.
Old Apr 6, 2004 | 12:50 PM
jimr's Avatar
Car Info: 2002 WRX Sedan
EJ20 use manual-followers, and like WW said they require a shim to adjust lash. The procedure actually looks fairly straightforward, provided you have the tool to compress the valve springs so the shim can be slid out.
You can download the info from Subaru for about $20.00.
Jim
B T W: my WRX makes a little tick too, always has. I am going to check valve lash @ 60K.
Old Apr 6, 2004 | 08:02 PM
Uncle Scotty's Avatar
OK....boys and girls....
My car 'ticked' from day one, bad, like a bad valve.....Until I put the STi injectors in.......NO 'ticking' after that....at all.....
phoneman
May 5, 2014 11:41 AM
LazyKidd209
Jan 29, 2011 03:35 PM
malus
Apr 8, 2007 10:24 PM
STi_rebirth
Jun 6, 2006 10:40 AM
1 fststi
May 6, 2006 04:13 PM
