EGT question
Old Jul 15, 2009 | 01:39 PM
lllRedline's Avatar
Car Info: 03 PSM WRX stg 2
EGT question
Just got a gutted uppipe not sure if I should put the EGT back in or just plug it with a bolt. If I put in the EGT, will it burn out?
Thanks!
Old Jul 16, 2009 | 12:42 AM
dogcatfud's Avatar
Car Info: 2015 FR-S
Just plug the hole and put a 2.2K ohm 1/2 watt resistor in the female end of the connector. Cover it with electrical tape and tuck it away.
Old Jul 16, 2009 | 12:37 PM
lllRedline's Avatar
Thanks that's what i've read from other sources. Will the EGT actually burn out if I leave it in there or will it just throw CELs?
lllRedline's Avatar
I'm also getting an AP which I know can clear CELs
Old Jul 16, 2009 | 02:02 PM
dickson's Avatar
Car Info: 2002 WRX Sedan, 2004 Acura TL
I asked GST the same question. They told me the EGT sensor will not blow out (at least on stage 2). Somewhat of an urban legend. It also serves as a good plug. Just make sure you do the resistor mod to the plug.
Old Jul 16, 2009 | 10:18 PM
lllRedline's Avatar
Are you using your EGT as plug with no problems?
I saw one guy post on nasioc saying he used his EGT for over 20k for logging w/o probs. I think I'm gonna grind off the EGT probe and use as a plug and solder in the resistor somehow so everything looks untouched
I doubt anyone will look closely at my uppipe but if I get pulled over or smogged, that is one piece I do not want to replace!
STiPilot
Dec 12, 2004 11:20 AM
silvrbulit04
Sep 8, 2004 11:23 AM
WindingRoad
Mar 16, 2004 07:39 AM
skoobywrx
Mar 3, 2003 07:54 PM
spdkills
Jan 25, 2003 03:48 PM
