does redline H2O wetter help?
Old Nov 19, 2003 | 10:59 AM
qwk_wrx's Avatar
Car Info: 05' Evo 8
Question does redline H2O wetter help?
Has anyone used the Redline oil water wetter, (the additive for the water in your radiator) it says that it will give a drop in temp up to 20 degrees celcius....does this really work...thanks
Old Nov 19, 2003 | 11:34 AM
Uncle Scotty's Avatar
Can't hurt....If it saves your motor once, I think it paid for itself.
Old Nov 19, 2003 | 11:52 AM
international B's Avatar
Chewwwwy
i have used it for years in many different cars. i bevieve it works, not 20 degrees, but it does help
Old Nov 19, 2003 | 11:55 AM
dropkick_muppet's Avatar
Car Info: '03 PSM Sedan
yes, it does work --but i'm not sure about the claim of helping by 20 degrees. i've used it extensively in motorcycles with just water (no ethyl glycol coolant) with excellent results. i wouldn't reccomend doing that in a daily driven car though.
Old Nov 19, 2003 | 11:58 AM
qwk_wrx's Avatar
Car Info: 05' Evo 8
thanks....what do you guys think the ratio for coolant should be...50/50 coolant and H2O, and add the water wetter.....or?
Old Nov 19, 2003 | 12:09 PM
andyhidley's Avatar
Car Info: 2002 WRX
water wetter is in a small bottle compared to the gallons in the cooling system. Just ad it to the overflow resivour and after 10 heat cycles it will be in the radiator
Old Nov 19, 2003 | 12:21 PM
i'd use 50/50 water/coolant, and then follow the directions on the back of water wetter. i think it's something like 1 cap ful per gallon of coolant, or something along those lines. i don't think you need the whole bottle.
Old Nov 19, 2003 | 03:50 PM
See: http://www.racerpartswholesale.com/redtech3.htm
for details on Water Wetter.
USE DIRECTIONS
One 12 ounce bottle treats 12- 16 quarts of water or a 50% ethylene or propylene glycol solution. In smaller cooling systems, use 4 - 5 caps per quart. Add directly through the cooling system fill cap into the radiator or into the overflow tank. Do not open a cooling system while hot. For best protection for aluminum, replenish or replace every 15,000 miles. The anti-scaling ingredients in Red Line Water Wetter allow its use with ordinary tap water. However, using with distilled or deionized water will accomplish some scale removal in the cylinder head area. For maximum temperature reductions use the most water and the least antifreeze possible to prevent freezing in your climate. Even in summertime the use of air-conditioning can blow freezing air through the heater and cause freezing of the heater core unless approximately 20% antifreeze is used. Red Line Water Wetter is available in 12 ounce containers.
Old Nov 19, 2003 | 08:30 PM
qwk_wrx's Avatar
Car Info: 05' Evo 8
thanks for the website...was very helpful...did it tonight and i kinda did notice a difference...plus if it will help save my engine, than 7.99 isn't that big of a deal.
Old Nov 23, 2003 | 01:50 AM
BongMan's Avatar
Car Info: '01 RS BRP
It basicly raises the boiling point or the mix. Which is a good thing on the track.
Old Nov 24, 2003 | 09:24 AM
ride5000's Avatar
no, it doesn't.
it increases the ability of the water to transfer heat. it also inhibits corrosion.
it does NOT provide anti-freeze, or anti-boil properties.
i use it.
ken
Old Nov 24, 2003 | 10:52 AM
andyhidley's Avatar
Car Info: 2002 WRX
ride5000 is correct
Antifreeze transfers heat WORSE than water, but it wont freeze. So for thoes of you who are goinng to put in straight antifreeze you'll loose cooling ability.
Straight water is great for cooling, but it freezes and has no lubricants or corrosion addativs
Lowend
Jul 26, 2006 08:20 PM
WrbImprezaSti
Jul 23, 2006 09:55 PM
GR8-WRX
Mar 16, 2004 08:59 AM
Bret
Jul 25, 2003 11:39 PM
gc8 pimp
Jul 1, 2003 12:18 PM
