Does the CEL fix for dp reduce power?
Old Jul 15, 2004 | 05:24 PM
kalasend's Avatar
Car Info: Aspen White GDA
Hello. I've notice some power loss after putting on the CEL fix for the downpipe O2 sensor.
I'm not 100% sure if this is due to the fix device. Apparently A/F ratio cannot be read after the fix. This does eliminate any throwing of the CEL but I wonder if it also retard the ECU's work......
Old Jul 15, 2004 | 06:33 PM
Kwilson21's Avatar
Car Info: 2003 WRX (Black)
Question
Interesting... i just had my uppipe and DP installed today with the cel fix done for the DP and notice definete boost issues / decrease in power. Matter of fact in the mid to high RPMs in both 2nd and 3rd it sputters and cuts..?!?!?... (see my post today Help!!).
I wonder if the ECU is going to learn and adjust for these upgrades?...
Old Jul 15, 2004 | 07:11 PM
kalasend's Avatar
Been 3~4 months for me
Old Jul 15, 2004 | 07:18 PM
Kwilson21's Avatar
really.
Do you have any engine managment running... i.e. accessport, EcuTek...???
Did it only occure after the cel fix?
-K
Old Jul 15, 2004 | 11:18 PM
kalasend's Avatar
No engine mgt. No, I'm not sure if this is tied to the cel fix.
However, if you think only of the fact that the ECU is not reading any O2 sensor data....I don't think that's a positive thing
Old Jul 16, 2004 | 07:14 AM
Kwilson21's Avatar
Do you have and aftermarket uppipe??... it has to be the ECU... there are so many people out there that have these setups. I wonder if they all go thru this.
My take is that the ECU is ajusting for the increased flow and mixing the fuel rich. I would think that maybe if we disconnect the negative battery terminal and do the reset mod posted somwhere on the forum that it might let the ECU get a new look..... or now might be a good time to do the ECU upgrade / reflash / reprogram w/ EcuTek. I'm a little warry of the access port despite the raves. It just doesnt have the ability to finite tune like the EcuTek.
K
Old Jul 17, 2004 | 02:30 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
both of you need to reset your ECU's and let them learn. You can try the learning trick if you like (hold the car at ~2900RPM with 1-2psi of boost for about 5-10 seconds... use your left foot on the brake). If that doesn't solve your problems, its likely mechanical.
-- Ed
Old Jul 17, 2004 | 04:23 PM
Kwilson21's Avatar
Question
-- Ed
ok?... so get her on the street, put my foot on the brake so the car wont move..... put it in 1st gear...... and step on the gas and slow the clutch out and run it at 2900RPM for 10 seconds..... kindof like im launching but much lower RPM......... right?.
-K
Old Jul 17, 2004 | 06:46 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
no.
This has to be done while moving, in 3rd or 4th gear, reach 2900RPM, gently brake with your left foot while applying a bit more gas with your right. You want to keep it around 2900RPM and have approx 1-2psi of boost. Do this for about 10 seconds and your IAM will jump to 16 (max).
-- Ed
lcjarrett
Feb 23, 2007 12:39 AM
esracer
Mar 16, 2004 11:56 AM
Jim Sanchez
Nov 29, 2003 06:46 AM
Tommy3rd
14
Apr 25, 2003 05:15 PM
Top
